RTEMS Source Build error
Joel Sherrill
joel at rtems.org
Thu Jan 19 18:20:49 UTC 2017
I see you are using Linux Mint 17.2. Is this the information you were
looking for?
https://docs.rtems.org/branches/master/rsb/hosts.html#linux-mint
On Thu, Jan 19, 2017 at 11:41 AM, dtitomanlio at tsd-space.it <
dtitomanlio at tsd-space.it> wrote:
> Hi,
> I do have zlib.h, actually there are three zlib.h files for each
> architecture in different folders. The point is that they are not found by
> the source builder, i.e. none of the folders is present in the include path
> Daniele
> On 1/19/2017 5:54 PM, DiGiorgio, Joseph wrote:
> I just went through using the “TEMS Source Builder” and once I installed
> all the dependencies it worked just fine. I would check to see if you have “zlib1g-dev”
> installed as that has zlib.h.
> - Joey D.
> *From:* users [mailto:users-bounces at rtems.org <users-bounces at rtems.org>] *On
> Behalf Of *dtitomanlio at tsd-space.it
> *Sent:* Thursday, January 19, 2017 11:34 AM
> *To:* users at rtems.org
> *Subject:* RTEMS Source Build error
> Hello,
> I'm trying to use the RTEMS Source builder for building the tool package
> for SPARC and ARM architectures. In both cases I get the same error:
> ../../gcc-6.3.0/gcc/lto-compress.c:34:18: fatal error: zlib.h: No such
> file or directory
> #include <zlib.h>
> the sb-check reports that "RTEMS Source Builder environment is ok"
> I'm using Linux Mint 17.2 with VirtualBox on Windows10 machine
> Any help is highly appreciated
> Best Regards
> Daniele
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20170119/f66a51d3/attachment.html>
