AW: RTEMS Source Build error
Jan.Sommer at dlr.de
Fri Jan 20 13:48:20 UTC 2017
Hi Daniele,
We had a similar problem recently. Have you installed the python-dev packages on your host?
Best regards,
Jan
Von: users [mailto:users-bounces at rtems.org] Im Auftrag von dtitomanlio at tsd-space.it
Gesendet: Freitag, 20. Januar 2017 14:26
An: joel at rtems.org
Cc: users at rtems.org
Betreff: Re: RTEMS Source Build error
Hi,
thank you, now the process continues close to the end, until another error is issued:
checking whether to use python... yes
checking for python... /usr/bin/python
checking for python2.7... no
configure: error: python is missing or unusable
make[1]: *** [configure-gdb] Error 1
make[1]: Leaving directory `/home/dat/development/rtems/src/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.12-i686-linux-gnu-1/build'
make: *** [all] Error 2
shell cmd failed: /bin/sh -ex /home/dat/development/rtems/src/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.12-i686-linux-gnu-1/doit
error: building sparc-rtems4.12-gdb-7.12-i686-linux-gnu-1
it seems it is not able to find or use python but the tool (version 2.7) is installed in /usr/bin, in fact I am able to run it from a terminal window
Daniele
On 1/19/2017 7:20 PM, Joel Sherrill wrote:
I see you are using Linux Mint 17.2. Is this the information you were looking for?
https://docs.rtems.org/branches/master/rsb/hosts.html#linux-mint
On Thu, Jan 19, 2017 at 11:41 AM, dtitomanlio at tsd-space.it<mailto:dtitomanlio at tsd-space.it> <dtitomanlio at tsd-space.it<mailto:dtitomanlio at tsd-space.it>> wrote:
Hi,
I do have zlib.h, actually there are three zlib.h files for each architecture in different folders. The point is that they are not found by the source builder, i.e. none of the folders is present in the include path
Daniele
On 1/19/2017 5:54 PM, DiGiorgio, Joseph wrote:
I just went through using the “TEMS Source Builder” and once I installed all the dependencies it worked just fine. I would check to see if you have “zlib1g-dev” installed as that has zlib.h.
- Joey D.
From: users [mailto:users-bounces at rtems.org] On Behalf Of dtitomanlio at tsd-space.it<mailto:dtitomanlio at tsd-space.it>
Sent: Thursday, January 19, 2017 11:34 AM
To: users at rtems.org<mailto:users at rtems.org>
Subject: RTEMS Source Build error
Hello,
I'm trying to use the RTEMS Source builder for building the tool package for SPARC and ARM architectures. In both cases I get the same error:
../../gcc-6.3.0/gcc/lto-compress.c:34:18: fatal error: zlib.h: No such file or directory
#include <zlib.h>
the sb-check reports that "RTEMS Source Builder environment is ok"
I'm using Linux Mint 17.2 with VirtualBox on Windows10 machine
Any help is highly appreciated
Best Regards
Daniele
users mailing list
http://lists.rtems.org/mailman/listinfo/users
[cid:image001.jpg at 01D2732C.3D8B2490]
Ing. Daniele Titomanlio
Techno System Dev. s.r.l.
Via Provinciale Pianura 2
Zona Ind. S. Martino, 23
80078 - Pozzuoli - ITALY
Web : www.tsd-space.it<http://www.tsd-space.it/>
Email: dtitomanlio at tsd-space.it<mailto:dtitomanlio at tsd-space.it>
Phone: +39 081 526 34 75
Fax : +39 081 526 27 01
Informativa sulla Privacy D.Lgs 196/2003
Le informazioni contenute nella comunicazione che precede possono essere riservate e sono, comunque, destinate esclusivamente alla persona o all'ente sopraindicati. La diffusione, distribuzione e/o copiatura del documento trasmesso da parte di qualsiasi soggetto diverso dal destinatario è proibita. La sicurezza e la correttezza dei messaggi di posta elettronica non possono essere garantite. Se avete ricevuto questo messaggio per errore, Vi preghiamo di contattarci immediatamente.
Grazie.
This communication is intended only for use by the address. It may contain confidential or privileged information. Transmission cannot be guaranteed to be secure or error-free. If you received this communication unintentionally, please inform us immediately.
Thank you.
URL: <http://lists.rtems.org/pipermail/users/attachments/20170120/02ad0ac6/attachment-0001.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.rtems.org/pipermail/users/attachments/20170120/02ad0ac6/attachment-0001.jpg>
