Strictly atomic operations
Mon Jan 23 08:37:48 UTC 2017
Hello Matt,
On 20/01/17 20:12, Matt Rippa wrote:
> Greetings,
> In VxWorks 5.5 we use taskLock()/taskUnlock() to stop the possibility
> of preemption for a critical region of code. This doesn't stop
> interrupts as described here:
> http://www.vxdev.com/docs/vx55man/vxworks/ref/taskLib.html#taskLock
> <http://www.vxdev.com/docs/vx55man/vxworks/ref/taskLib.html#taskLock>
there is currently no API function for this.
> What would be the recommended approach in rtems? Using semaphores
> would not prevent a higher priority thread from preempting me.
The thread dispatch disable level used internally would provide the
functionality of taskLock()/taskUnlock(). What is your use case for
this? Why can't you use a mutex?
The Universal Memory Allocator (UMA) of libbsd disables thread
dispatching to access the per-processor caches, however, it should be
quite rare to have such a use case at application level.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
