make lto-compress.o error & build recovery question
Karim, Hassan
hassan.karim at bison.howard.edu
Wed Jan 25 01:14:26 UTC 2017
Thanks Alan. So that confirms... it is very slow. Would you say it took the
full day to do all of the compiling. Mine is taking 3-5 hrs each time I
have to restart (because of missing packages).
>From the list that you presented, I was missing ncurses-dev python-dev
zlib1g-dev. I forgot that I had only installed zlib1g-dev on another
machine. On that machine I was missing python and ncurses too.
But apt-get complained about the python-dev not being certifiable. Is the
following message normal or has it been compromised?
WARNING: The following packages cannot be authenticated!
flex libfl-dev python2.7 libpython2.7 libpython2.7-stdlib
python2.7-minimal
libpython2.7-minimal libexpat1-dev libpython2.7-dev python2.7-dev
Regards,
*Hassan Karim, CISSP*
https://www.linkedin.com/in/hassankarimcissp
Comp Sci Ph.D. Student
Howard University
(202) 569-1012
On Tue, Jan 24, 2017 at 7:55 PM, Alan Cudmore <alan.cudmore at gmail.com>
wrote:
> I was able to build both toolchains ( sparc and arm ) , compile RTEMS for
> arm/raspberrypi, and build an application with a waf makefile. Except for
> being very slow, it seems very compatible with Ubuntu.
> If you build RTEMS with the test suite, you will also need to install pax
> ( sudo apt-get install pax ).
> Alan
> On Jan 24, 2017, at 7:22 PM, Karim, Hassan <hassan.karim at bison.howard.edu>
> wrote:
> Ok. Thanks. I will retry
> Regards,
> Hassan Karim, CISSP
> Ph.D. Student
> Computer Science
> Howard University
> +1202-569-1012 <(202)%20569-1012>
> On Jan 24, 2017 5:53 PM, "Alan Cudmore" <alan.cudmore at gmail.com> wrote:
>> So far I have built the arm-rtems4.12 tools on WSL. It’s working on
>> sparc-rtems4.12 now.
>> Seems OK so far.
>> Alan
>> On Jan 24, 2017, at 5:34 PM, Karim, Hassan <hassan.karim at bison.howard.edu>
>> wrote:
>> Those are the same packages I installed on one computer. I will confirm
>> on the other.
>> Regards,
>> Hassan Karim, CISSP
>> Ph.D. Student
>> Computer Science
>> Howard University
>> On Jan 24, 2017 11:09 AM, "Alan Cudmore" <alan.cudmore at gmail.com> wrote:
>>> Hi,
>>> By WLS, do you mean the Windows Subsystem for Linux?
>>> I was able to build a toolchain when it was first released.
>>> I submitted this RSB doc patch, but I don’t know if it made it in:
>>> https://lists.rtems.org/pipermail/devel/2016-August/015866.html
>>> As to how to resolve it, there should be a log file with a more specific
>>> error. From what I know, you do have to restart the build process.
>>> I found that I had to install a few more packages than a standard Ubuntu
>>> install to get the toolchain to build.
>>> Here is what I had to install:
>>> $ sudo apt-get install autoconf automake bison flex binutils gcc \
>>> +g++ gdb texinfo unzip ncurses-dev python-dev git zlib1g-dev make
>>> I’m going to try this again, to make sure I can still build my sparc and
>>> ARM tools.
>>> Alan
>>> On Jan 24, 2017, at 10:44 AM, Karim, Hassan <
>>> hassan.karim at bison.howard.edu> wrote:
>>> Gurus:
>>> I am trying to build RTEMS tool set on Ubuntu for WLS. Making progress.
>>> but then after several hours, build failed. I got the errors below. ANy
>>> idea how to resolve and better yet, how to not spend another 5 hrs getting
>>> to the point where the next issue pops up. In other words, do I have start
>>> from ground 0 everytime I encounter a bug?
>>> make[2]: *** [lto-compress.o] Error 1
>>> make[2]: *** Waiting for unfinished jobs....
>>> rm gcc.pod
>>> make[2]: Leaving directory `/home/drhass/RTEMS/src/rtems-
>>> source-builder/rtems/build/sparc-rtems4.12-gcc-6.3.0-newlib-
>>> 2.5.0-x86_64-linux-gnu-1/build/gcc'
>>> make[1]: *** [all-gcc] Error 2
>>> make[1]: Leaving directory `/home/drhass/RTEMS/src/rtems-
>>> 2.5.0-x86_64-linux-gnu-1/build'
>>> make: *** [all] Error 2
>>> shell cmd failed: /bin/sh -ex /home/drhass/RTEMS/src/rtems-
>>> 2.5.0-x86_64-linux-gnu-1/doit
>>> error: building sparc-rtems4.12-gcc-6.3.0-newl
>>> ib-2.5.0-x86_64-linux-gnu-1
>>> Regards,
>>> Howard University
>>> (202) 569-1012
>>> users mailing list
>>> users at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20170124/d6877cce/attachment-0001.html>
