RTEMS and gtest
    Sebastian Huber
    Thu Jan  5 11:19:44 UTC 2017
Hello Jan,
----- Am 5. Jan 2017 um 11:21 schrieb Jan Sommer soja-lists at aries.uberspace.de:
> Hi,
> I stumbled across this repository of Sebastian
> https://git.rtems.org/sebh/rtems-gtest.git/ .
> How well does gtest work on rtems?
everything I used worked. To install it, see the rtems/README.
> Is it enough to have only the
> classic-API or is the posix API needed?
You need the POSIX API enabled.
