can't build application from example-v2
Denis Obrezkov denisobrezkov at gmail.com
Sun Jan 8 16:50:34 UTC 2017
2017-01-08 17:50 GMT+02:00 Alan Cudmore <alan.cudmore at gmail.com>:
> I was able to get the waf configure step for the examples-v2 repository to
> work with sparc/erc32 ( 4.12 )
> In your —rtems= switch, does it point to where you installed the BSP? ( as
> opposed to the source )
> Mine looks like this:
> waf configure —rtems=$HOME/rtems/bsps/4.12 —rtems-tools=$HOME/rtems/tools/4.12
> —rtems-version=4.12 —rtems-bsps=sparc/erc32
> While the configure step worked for me, I was not able to get the
> repository to build for the sparc/erc32.
> I can build some of the individual examples by going into a directory:
> cd hello/hello_world_c
> waf
> But others fail. I’ll try it with an ARM bsp soon.
> Alan
Yes, I think I misunderstood the option's meaning. Also, I downloaded
rtems-tools, built them with waf,
and insert their path into --rtems-tools variable, and that didn't worked.
So, then I inserted a path to
cross-compilers and etc. and it works. It was a bit ambiguous for me.
Regards, Denis Obrezkov
URL: <http://lists.rtems.org/pipermail/users/attachments/20170108/27239578/attachment-0002.html>
