make lto-compress.o error & build recovery question
Karim, Hassan
hassan.karim at bison.howard.edu
Tue Jan 24 22:34:09 UTC 2017
Those are the same packages I installed on one computer. I will confirm on
the other.
Regards,
Hassan Karim, CISSP
Ph.D. Student
Computer Science
Howard University
+1202-569-1012
On Jan 24, 2017 11:09 AM, "Alan Cudmore" <alan.cudmore at gmail.com> wrote:
> Hi,
> By WLS, do you mean the Windows Subsystem for Linux?
> I was able to build a toolchain when it was first released.
> I submitted this RSB doc patch, but I don’t know if it made it in:
> https://lists.rtems.org/pipermail/devel/2016-August/015866.html
> As to how to resolve it, there should be a log file with a more specific
> error. From what I know, you do have to restart the build process.
> I found that I had to install a few more packages than a standard Ubuntu
> install to get the toolchain to build.
> Here is what I had to install:
> $ sudo apt-get install autoconf automake bison flex binutils gcc \
> +g++ gdb texinfo unzip ncurses-dev python-dev git zlib1g-dev make
> I’m going to try this again, to make sure I can still build my sparc and
> ARM tools.
> Alan
> On Jan 24, 2017, at 10:44 AM, Karim, Hassan <hassan.karim at bison.howard.edu>
> wrote:
> Gurus:
> I am trying to build RTEMS tool set on Ubuntu for WLS. Making progress.
> but then after several hours, build failed. I got the errors below. ANy
> idea how to resolve and better yet, how to not spend another 5 hrs getting
> to the point where the next issue pops up. In other words, do I have start
> from ground 0 everytime I encounter a bug?
> make[2]: *** [lto-compress.o] Error 1
> make[2]: *** Waiting for unfinished jobs....
> rm gcc.pod
> make[2]: Leaving directory `/home/drhass/RTEMS/src/rtems-
> source-builder/rtems/build/sparc-rtems4.12-gcc-6.3.0-
> newlib-2.5.0-x86_64-linux-gnu-1/build/gcc'
> make[1]: *** [all-gcc] Error 2
> make[1]: Leaving directory `/home/drhass/RTEMS/src/rtems-
> newlib-2.5.0-x86_64-linux-gnu-1/build'
> make: *** [all] Error 2
> shell cmd failed: /bin/sh -ex /home/drhass/RTEMS/src/rtems-
> newlib-2.5.0-x86_64-linux-gnu-1/doit
> error: building sparc-rtems4.12-gcc-6.3.0-newlib-2.5.0-x86_64-linux-gnu-1
> Regards,
> *Hassan Karim, CISSP*
> https://www.linkedin.com/in/hassankarimcissp
> Comp Sci Ph.D. Student
> Howard University
> (202) 569-1012
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20170124/18cefc9e/attachment-0002.html>
