make lto-compress.o error & build recovery question
Karim, Hassan hassan.karim at bison.howard.edu
Wed Jan 25 00:22:53 UTC 2017
Ok. Thanks. I will retry
Regards,
Hassan Karim, CISSP
Ph.D. Student
Computer Science
Howard University
+1202-569-1012
On Jan 24, 2017 5:53 PM, "Alan Cudmore" <alan.cudmore at gmail.com> wrote:
> So far I have built the arm-rtems4.12 tools on WSL. It’s working on
> sparc-rtems4.12 now.
> Seems OK so far.
> Alan
> On Jan 24, 2017, at 5:34 PM, Karim, Hassan <hassan.karim at bison.howard.edu>
> wrote:
> Those are the same packages I installed on one computer. I will confirm on
> the other.
> Regards,
> Hassan Karim, CISSP
> Ph.D. Student
> Computer Science
> Howard University
> +1202-569-1012 <(202)%20569-1012>
> On Jan 24, 2017 11:09 AM, "Alan Cudmore" <alan.cudmore at gmail.com> wrote:
>> Hi,
>> By WLS, do you mean the Windows Subsystem for Linux?
>> I was able to build a toolchain when it was first released.
>> I submitted this RSB doc patch, but I don’t know if it made it in:
>> https://lists.rtems.org/pipermail/devel/2016-August/015866.html
>> As to how to resolve it, there should be a log file with a more specific
>> error. From what I know, you do have to restart the build process.
>> I found that I had to install a few more packages than a standard Ubuntu
>> install to get the toolchain to build.
>> Here is what I had to install:
>> $ sudo apt-get install autoconf automake bison flex binutils gcc \
>> +g++ gdb texinfo unzip ncurses-dev python-dev git zlib1g-dev make
>> I’m going to try this again, to make sure I can still build my sparc and
>> ARM tools.
>> Alan
>> On Jan 24, 2017, at 10:44 AM, Karim, Hassan <
>> hassan.karim at bison.howard.edu> wrote:
>> Gurus:
>> I am trying to build RTEMS tool set on Ubuntu for WLS. Making progress.
>> but then after several hours, build failed. I got the errors below. ANy
>> idea how to resolve and better yet, how to not spend another 5 hrs getting
>> to the point where the next issue pops up. In other words, do I have start
>> from ground 0 everytime I encounter a bug?
>> make[2]: *** [lto-compress.o] Error 1
>> make[2]: *** Waiting for unfinished jobs....
>> rm gcc.pod
>> make[2]: Leaving directory `/home/drhass/RTEMS/src/rtems-
>> source-builder/rtems/build/sparc-rtems4.12-gcc-6.3.0-newlib-
>> 2.5.0-x86_64-linux-gnu-1/build/gcc'
>> make[1]: *** [all-gcc] Error 2
>> make[1]: Leaving directory `/home/drhass/RTEMS/src/rtems-
>> 2.5.0-x86_64-linux-gnu-1/build'
>> make: *** [all] Error 2
>> shell cmd failed: /bin/sh -ex  /home/drhass/RTEMS/src/rtems-
>> 2.5.0-x86_64-linux-gnu-1/doit
>> error: building sparc-rtems4.12-gcc-6.3.0-newlib-2.5.0-x86_64-linux-gnu-1
>> Regards,
>> *Hassan Karim, CISSP*
>> https://www.linkedin.com/in/hassankarimcissp
>> Comp Sci Ph.D. Student
>> Howard University
>> (202) 569-1012
>> users mailing list
>> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20170124/6dcdb174/attachment-0002.html>
