stdout and stderr are getting mixed up?
Mon Jul 3 06:08:11 UTC 2017
On 30/06/17 15:01, Sebastian Huber wrote:
> Hello,
> would you mind testing with the latest tool chain (RSB) and the latest
> RTEMS master:
> https://git.rtems.org/rtems/commit/?id=9b07f5efe364bc52b80eff83389ee4bf4a1e0c40
> https://git.rtems.org/rtems-source-builder/commit/?id=5ede1c7e8b1874bbac2f8a3d158bd1c7d802156d
> I changed Newlib to use global stdio stream FILE objects. With this
> change a freopen(..., stdin) etc. will close the global stdin FILE
> object. In order to create thread-local stdio stream objects, you have
> to use stdin = fopen(...), etc.
Ok, I should have read the subject more closely. I think its perfectly
fine that stdout and stderr streams are mixed up. I did run the attached
program on Linux and I get:
gcc -O2 test.c -pthread && ./a.out 2>&1 | grep ab
aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaabbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbb
aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaabbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbb
aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaabbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbb
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
Type: text/x-csrc
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20170703/94b2a09e/attachment.bin>
