Dynamic load real-time tasks
Павел Жданов
paul.alex.zhdanov at gmail.com
Tue Jul 4 09:10:13 UTC 2017
> > i386-rtems4.11-gcc -B../../../../../pc486/lib/ -specs bsp_specs
> -qrtems -mtune=i486 -O2 -g -Wall -Wmissing-prototypes
> -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs
> -Wl,-Ttext,0x00100000 -mtune=i486 -o dl01.pre.exe init.o dl-load.o
> dl-o1.o filesystem.o
> > mv dl01.pre.exe dl01.pre
> > rtems-syms -e -c "-mtune=i486 -O2 -g -Wall -Wmissing-prototypes
> -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs" -o
> dl-sym.o dl01.pre
> -Wl,-Ttext,0x00100000 -mtune=i486 -o dl01.exe init.o dl-load.o dl-o1.o
> dl-sym.o filesystem.o
> You have linked the object you wish to run time load into the base kernel
> executable.
> Chris
Thanks Chris. So far I can't solve this problem.
I'm sorry for the stupid newbie questions but I just don't get the
mechanism.
I have a printf symbol in the base image dl.exe.
I load the object file dl.o that uses printf. dl.o.
dl.c contains rtems_main and printf functions. dl.o is obtained using the
following command:
i386-rtems4.11-gcc -B$(RTEMS_MAKEFILE_PATH)lib/ -specs bsp_specs -qrtems
-DHAVE_CONFIG_H -I. -I.. -I./include -mtune=i486 -O2 -g -Wall
-Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes
-Wnested-externs -MT dl.o -MD -MP -MF .deps/dl.Tpo -c -o dl.o dl.c
Symbol table dl-sym.o is obtained using the following commands:
-mtune=i486 -O2 -g \
-Wall -Wmissing-prototypes -Wimplicit-function-declaration
-Wstrict-prototypes -Wnested-externs \
-Wl,-Ttext,0x00100000 -mtune=i486 -o dl.pre init.o filesystem.o dl.o
dl-sym.o dl.pre
It's content is:
Symbol table '.symtab' contains 1999 entries:
Num: Value Size Type Bind Vis Ndx Name
0: 00000000 0 NOTYPE LOCAL DEFAULT UND
1: 00000000 0 FILE LOCAL DEFAULT ABS rld--YAfaaa.c
2: 00000000 0 SECTION LOCAL DEFAULT 1
3: 00000000 0 SECTION LOCAL DEFAULT 3
4: 00000000 0 SECTION LOCAL DEFAULT 4
5: 00000000 0 SECTION LOCAL DEFAULT 5
6: 00000000 0 NOTYPE LOCAL DEFAULT 5 rtems__rtl_base_globals
7: 0000c1cc 0 NOTYPE LOCAL DEFAULT 5 rtems__rtl_base_globals_s
8: 00000000 0 SECTION LOCAL DEFAULT 7
9: 00000000 0 SECTION LOCAL DEFAULT 9
10: 00000000 0 SECTION LOCAL DEFAULT 8
11: 00000000 0 NOTYPE GLOBAL DEFAULT UND BSPPrintkPort
12: 00000000 0 NOTYPE GLOBAL DEFAULT UND BSP_get_current_rtems_irq
13: 00000000 0 NOTYPE GLOBAL DEFAULT UND BSP_inch
1051: 00000000 0 NOTYPE GLOBAL DEFAULT UND preserve_fd_acls
1052: 00000000 0 NOTYPE GLOBAL DEFAULT UND printCpuInfo
1053: 00000000 0 NOTYPE GLOBAL DEFAULT UND printf
1054: 00000000 0 NOTYPE GLOBAL DEFAULT UND printk
1055: 00000000 0 NOTYPE GLOBAL DEFAULT UND printk_plugin
1356: 00000000 0 NOTYPE GLOBAL DEFAULT UND rtems_main
Is it correct that all symbols are undefined?
When I load dl.o with dl_open the rtl is looking for the symbols from
.rel.text section in local and global symbol tables of dl.o.
Relocation section '.rel.text' at offset 0x618 contains 2 entries:
Offset Info Type Sym.Value Sym. Name
00000027 00000501 R_386_32 00000000 .rodata.str1.1
0000002c 00001002 R_386_PC32 00000000 printf
rtl can't find printf.
I don't link any files against dl-sym.o. Is it possible to use printf of
base image or I need to link dl.o against libc?
Best regards,
Pavel.
URL: <http://lists.rtems.org/pipermail/users/attachments/20170704/cad17c6b/attachment-0001.html>
