c++11 std::atomic
Thu Jul 13 05:00:10 UTC 2017
On 12/07/17 14:13, Mikhail Svetkin wrote:
> I updated RSB and RTEMS, but i had the same problem.
> arm-rtems4.12-gcc -v
> (gcc version 7.1.0 20170502 (RTEMS 4.12, RSB
> f3b8da031e42d126afd94d17582123f66b78a68, Newlib 2.5.0.20170623) (GCC
The latest RSB is 83973200f0e69a897f9a35d68a689ce706dcfb78, but this
version is all right if you don't have an SMP system.
> rtems-git (e19da87ad706bf79fa0e22f1f7d68e21bca2e296)
Ok.
> Also i tried this example on sparc simulator and it's ok.
I tried this example on the realview_pbx_a9_qemu BSP. I am quite
interested to find the problem. Which BSP do you use? Can you debug the
example and figure out what "program is not responding" is actually?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
