Building RTEMS for BeagleBone Black failed
Russell Haley russ.haley at gmail.com
Mon Jul 17 15:33:51 UTC 2017
Hi, I seem to get the same error. I made the assumption that the bset
for the beagle board name has changed from devel/beagle.bset to
rtems-arm.bset based on the seb config directory.
My steps:
cd ~/Git
mkdir rtems
git clone git://git.rtems.org/rtems-source-builder.git
cd rtems-source-builder/source-builder
./sb-check
#RTEMS Source Builder - Check, 4.12 (e2952bb185c1)
#warning: exe: absolute exe found in path: (__unzip)
/usr/local/bin/unzip
#Environment is ok
cd ..
cd rtems
../source-builder/sb-set-builder --log=beagle.txt
--prefix=/usr/home/russellh/Git/rtems/rtems-source-builder/rtems/config/4.12
config/4.12/rtems-arm.bset
Error report is here:
https://pastebin.com/RhR3Q17g
It looks like the same issue?
Russ
On Sun, Jul 16, 2017 at 10:07 PM, Sebastian Huber
> On 16/07/17 22:13, Russell Haley wrote:
>> RTEMS Tools Project - Source Builder Error Report
>>   Build: error: building
>> arm-rtems4.12-gcc-6.3.0-newlib-2.5.0.20170228-x86_64-freebsd12.0-1
> This is an old RSB version, please try it with the latest RSB and RTEMS
> master branch.
