rtems on raspberry pi 2 difficultys
William Kirstaedter
kirstaedter at fhi-berlin.mpg.de
Mon Jul 17 15:45:18 UTC 2017
thanks!!!
I cant believe that this really solved the issue, but it does.
have a nice evening,
William Kirstaedter (PP&B)
Fritz-Haber-Institut der MPG
Faradayweg 4-6
14195 Berlin
Tel: 030 8413 3154
Mail: kirstaedter at fhi-berlin.mpg.de
Am 17.07.2017 um 17:34 schrieb Alan Cudmore:
> I will have to find the information at home later tonight. But you
> could always try to use firmware that is 1 year old:
> https://github.com/raspberrypi/firmware/tree/1.20160620/boot
> Alan
> On Mon, Jul 17, 2017 at 11:14 AM, William Kirstaedter
> <kirstaedter at fhi-berlin.mpg.de <mailto:kirstaedter at fhi-berlin.mpg.de>>
> wrote:
> that would be wonderful :)
> Faradayweg 4-6
> 14195 Berlin
> Tel: 030 8413 3154
> Mail:kirstaedter at fhi-berlin.mpg.de <mailto:kirstaedter at fhi-berlin.mpg.de>
> Am 17.07.2017 um 17:13 schrieb Alan Cudmore:
>> I have not updated my Raspberry Pi / RTEMS environment in a
>> while, but I recall similar problems with the latest Raspberry PI
>> firmware. I was able to use a specific release and make RTEMS
>> work. I'll see if I can find the details.
>> Alan
>> On Mon, Jul 17, 2017 at 9:15 AM, Andreas Kölbl
>> <andreas.koelbl at st.oth-regensburg.de
>> <mailto:andreas.koelbl at st.oth-regensburg.de>> wrote:
>> Am 17.07.2017 um 13:29 schrieb William Kirstaedter:
>> > Hi @all,
>> > I hope I am asking in the right mailing list.
>> > This probably has already been asked, but I wasnt able to find
>> > anything suiting my problem case.
>> > I want to run RTEMS (and later on EPICS, but this shall not
>> be part of
>> > this request here) on my Raspberry Pi 2 B.
>> > So I followed various guides on how to get RTEMS compiled
>> for ARM /
>> > raspberry pi, and got a seemingly successful build of RTEMS
>> 4.12
>> > including the sample programs.
>> > I then made a binary out of the ticker.exe and copied it
>> over onto my
>> > boot partition of the SD card. neccessary proprietary broadcom
>> > bootloader files are present.
>> > Now when I try and turn the raspi on, it just shows the
>> color splash
>> > screen on HDMI and prints out unreadable, strange
>> characters on UART
>> > console. they are not always the same.
>> > (I try to append an Image)
>> > the same happens with hello.exe and the older RTEMS 4.11.
>> > Normally the Raspberry should display readable status
>> messages on UART
>> > for approx. 35 seconds and then halt.
>> > Maybe somebody here has an Idea whats the issue? Do I have
>> to tell
>> > RTEMS (somehow) what serial connection should be used and
>> at what
>> > speed it should operate? I am really new to RTEMS and therefore
>> > missing even an Idea where to start searching.
>> > Or should I ask in devel mailing list too?
>> which baud rates did you try? The README file located in
>> c/src/lib/libbsp/arm/raspberrypi/README states, you should be
>> able to
>> see output on PL011 UART0 at 115200 Baud and 8N1 encoding set
>> to your
>> console.
>> E.g. /dev/ttyUSB0 is a serial to usb converter ->
>> stty -F /dev/ttyUSB0 115200 cs8 -cstopb -parenb
>> should fit.
>> A framebuffer console should also be available.
>> > Thanks in advance;
>> > _______________________________________________
>> > users mailing list
>> > users at rtems.org <mailto:users at rtems.org>
>> > http://lists.rtems.org/mailman/listinfo/users
>> <http://lists.rtems.org/mailman/listinfo/users>
>> users mailing list
>> users mailing list
URL: <http://lists.rtems.org/pipermail/users/attachments/20170717/7b0b265c/attachment.html>
