Building RTEMS for BeagleBone Black failed
Russell Haley russ.haley at gmail.com
Tue Jul 18 15:07:21 UTC 2017
On Mon, Jul 17, 2017 at 11:39 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 18/07/2017 01:33, Russell Haley wrote:
>> Hi, I seem to get the same error. I made the assumption that the bset
>> for the beagle board name has changed from devel/beagle.bset to
>> rtems-arm.bset based on the seb config directory.
> I think the beagle.bset was a special made by Ben and it was never accepted into
> the master repo. I cannot remember what the build set contains.
> A board build set would need to reside under 'boards/beagle.bset' and while I
> see some value in these it increases the amount of testing we need to do when
> making changes, releasing and testing. I would be more included to accept a
> board build set patch if there was an active maintain for each one.
Okay, I remember this conversation now. I would be happy to try and
extend Ben's work towards getting a bset in the repo, but perhaps I
should build rtems at least once before volunteering for something.
tee hee. I have six more days off of work (with no kids!) so I am
trying to cram as much of this into one week as possible.
Either way, the redefinition error I am getting seems to be long
before we get to board specific configuration. It's happening in the
compilation of /gcc-6.3.0/gcc/gencheck.c (the file in question is
./options.h). My C is not strong enough to take it much further.
So I see the following options for me (input appreciated):
- Try a different platform. I have a Debian Jessie image I can build on.
- Try a different board package on FreeBSD. I will perhaps concede
defeat and build the emulator instead.
Some things I am having trouble keeping straight in my head:
1)Given a project setup of:
 ~/Git/
->rtems/
-->rtems-source-builder/
-->src/
-->b-bbb/
-->b-erc32/
Can I expect to be able to build for more than one target and have the
output wind up in the b-bbb or b-erc32 directories? All input on my
project layout is welcome.
2) What is the function of the --prefix? Is that supposed to point to
my overall install path, the source path, or my output path? So given
the previous paths, my --prefix would be ${HOME}/Git/rtems?
Thanks,
Russ
