Building RTEMS for BeagleBone Black failed
Fri Jul 21 03:03:28 UTC 2017
On 21/07/2017 12:49, Russell Haley wrote:
> On Wed, Jul 19, 2017 at 11:25 PM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> This looks like a FreeBSD 12 issue. Can you build a native GCC 7.1 on this
>> platform? The options.h file is automatically generated. Maybe there is an
>> issue with this.
> So I finally got an 11.0-RELEASE jail built and followed the quick
> start. Interestingly, the rsb is pulling it's host information from
> uname so when run in a jail it still configures itself for the host,
> not the jail. In this case 12.0-CURRENT. Surprisingly it completed.
> <shaking of head>
The FreeBSD host logic is here:
https://git.rtems.org/rtems-source-builder/tree/source-builder/sb/freebsd.py
> I'll try building the code with the sparc emulator example from the
> website and then loop around to the BB again later.
That is a good idea.
