Has anyone tried to port Mono to RTEMS
Mon Jul 24 00:11:30 UTC 2017
On 24/07/2017 09:29, Russell Haley wrote:
> I've retreated from FreeBSD all together. I'm on Debian Jessie right now. rsb is
> running and Mono is compiling now (still compiling C, not yet into mcs where it
> compiles the framework). I saw the original posters timezone item go whizing
> past so it's not a problem with my system so far. Will know more when I get rsb
> completed.
Interesting. This would imply something is not full crossed to the RTEMS
environment in Mono or the RTEMS environment is not consistent. The RTEMS
environment should be consistent across a range of host machines and so it
should give the same results to configure probes.
One issue I find when on FreeBSD is configure or build logic based around sed
breaks. If the sed logic uses GNU sed extensions, for example '\n' for a new
line, it breaks the BSD sed as it does not support it.
