pthread_getspecific fails after some calls in the same thread(task?)
Heinz Junkes junkes at fhi-berlin.mpg.de
Mon Jul 24 10:01:42 UTC 2017
I'm still trying to port EPICS to RTEMS 4.12 (4.11.99). I try to make the whole with posix threads
and run into the following issue by using pthread_getspecific (I get the same for me not expected result
when I use __thread variable instead).
In a function “once” called bei pthread_once I create a thread bounded key with
pthread_key_create(&getpthreadInfo,0);
The “key” is defined with
static epicsThreadOSD *createImplicit(void);
 static void epicsThreadInit(void)
      static pthread_once_t once_control = PTHREAD_ONCE_INIT;
      int status = pthread_once(&once_control,once);
      checkStatusQuit(status,"pthread_once","epicsThreadInit");
If I print out the position and value of this created key with
fprintf(stderr,"getpthreadInfo content = 0x%lx at %p\n",getpthreadInfo,&getpthreadInfo );
I get during run-time :
getpthreadInfo content = 0x13010003 at 0x22b6b8
and with further running the following function get called:
epicsShareFunc epicsThreadId epicsShareAPI epicsThreadGetIdSelf(void) {
  epicsThreadOSD *pthreadInfo;
     epicsThreadInit();
     fprintf(stderr,"epicsThreadGetIdSelf: getpthreadInfo content = 0x%lx at %p\n",getpthreadInfo,&getpthreadInfo );
     pthreadInfo = (epicsThreadOSD *)pthread_getspecific(getpthreadInfo);
     fprintf(stderr,"epicsThreadGetIdSelf:getspecific getpthreadInfo for tid 0x%x = %p\n", pthread_self(), pthreadInfo);
     if(pthreadInfo==NULL)
         pthreadInfo =  createImplicit();
     assert( pthreadInfo );
     return(pthreadInfo);
There is just one task (posix thread tid 0xb010001) running which does different initializations …
works so far:
epicsThreadOnce id = 0x0, func to call : 0x6346c
epicsThreadGetIdSelf: getpthreadInfo content = 0x13010003 at 0x22b6b8
epicsThreadGetIdSelf:getspecific getpthreadInfo for tid 0xb010001 = 0x2bcb58
epicsThreadOnce id = 0x22b6d4, func to call : 0x504d4
epicsThreadOnce id = 0x0, func to call : 0x4b08c
but at one point ( 7 times it goes well, can this be a hint?) it fails:
epicsThreadOnce id = 0x0, func to call : 0x41410
epicsThreadGetIdSelf:getspecific getpthreadInfo for tid 0xb010001 = 0x0
Any idea what might go wrong? Am I doing something wrong?
Unfortunately, I do not understand the assignment of rtems-tasks to posix-threads ;-(
Thank you,
Heinz
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20170724/b4b438cb/attachment.bin>
