Running RTEMS on a LEON2 from ROM
Mike Looijmans mike.looijmans at topic.nl
Tue Jul 25 12:36:38 UTC 2017
On 25-07-17 12:51, Mike Looijmans wrote:
> On 25-07-17 12:13, Jiri Gaisler wrote:
>> I haven't looked at this for a while, but I remember that the trap table
>> usually sits in the beginning of the .text segment. RTEMS overwrites the
>> trap entries at boot so if the trap table is in PROM, you will get a
>> memory exception trap. To run from PROM, you will need to allocate a new
>> trap table in RAM (4k aligned) and change the %tbr register to point to
>> it. This has to be done early before the trap table is initialized by
> Any hint on where this trap table allocation should happen in RTEMS code?
>> RTEMS. An elegant way of doing this would be to place the trap table in
>> a separate linker section, and then putting it to the desired place with
>> a custom linker file. The %tbr register should then be initialized to
>> the start of the trap table section.
> Simplest would be to put the trap table at the start of RAM (which will always
> have page alignment) and let the data segment follow on that.
> Simply directing the table into the data segment would work as well, I guess,
> the init code copies it on boot along with the rest of the initialized data then.
I did just that, the trap table now is at start of RAM, I left a small init
vector at address 0 in ROM to jump to the startup code.
After copying the .data segment into RAM, I set the %tbr register, enable
traps and continue. The table is indeed there at the first 4k of RAM now.
This executes okay, but no improvement yet. It does not even reach a
breakpoint at "bsp_pretasking_hook".
Still RTEMS silently locks up. I'm soft of bisecting now how far it goes,
since the backtrace is still blank ....
M.
Kind regards,
Mike Looijmans
System Expert
TOPIC Products
Materiaalweg 4, NL-5681 RJ Best
Postbus 440, NL-5680 AK Best
Telefoon: +31 (0) 499 33 69 79
E-mail: mike.looijmans at topicproducts.com
Website: www.topicproducts.com
Please consider the environment before printing this e-mail
