'MCLBYTES' undeclared here BSP
Wed Jul 26 08:58:40 UTC 2017
On 26/07/17 09:47, mfg wrote:
> Whenever I build a project after to create a new BSP the next error
> appears:
> /home/marco/BSPs/ZedboardBACON/arm-rtems4.12/xilinx_zynq_zedboard/lib/include/sys/mbuf.h:193:15:
> error: 'MCLBYTES' undeclared here (not in a function)
> Normally I declare the variable with a value 256, 512, 1024 or 2048
> and I can continue without errors. I would like to know if I am doing
> something silly or if that value should be fixed or it would have to
> be declared elsewhere.
You probably use a wrong tool chain/RTEMS combination or files from a
previous version. I would update to the latest RSB and RTEMS and remove
the previous installation.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
