Running RTEMS on a LEON2 from ROM
Mike Looijmans mike.looijmans at topic.nl
Wed Jul 26 09:01:35 UTC 2017
Here's my latest grmon2 session. I'm using the "hello" sample application as
reference now, which I find here after (deleting all files and) building the bsp:
sparc-rtems4.11/c/ml506l2/testsuites/samples/hello/hello.ralf
Mysterious. It gets to the "st  %g1, [%g1 + 0x8]" instruction, which
apparently writes to 0x400028A8 which is an okay location in RAM. Then the
next instruction just "hangs", when i hit ctrl-C after a minute or so, I get
the backtrace as below.
I really don't have a clue...
grmon2> bp hard 0x000063ac
   Hardware breakpoint 3 at 0x000063AC
grmon2> reset
   Hardware breakpoint 4 at 0x000063AC
grmon2> run 0
   breakpoint 3 hit
   0x000063ac: c2206008  st  %g1, [%g1 + 0x8]  <_API_extensions_Initialization+24>
grmon2> reg
          INS        LOCALS     OUTS       GLOBALS
      0:  00000000   00000FC6   400FFF40   00000000
      1:  00000000   000003B0   00000001   400028A0
      2:  00000000   000003B4   00000000   40002800
      3:  00000000   00000FC6   40002500   400028A4
      4:  00000001   00000800   00000000   51CF6D71
      5:  40002800   00000000   00000001   FFFFFFFF
      6:  400FFF40   00000000   400FFEE0   00000000
      7:  000003C8   00000000   00005F60   00000000
    psr: 00900FE6   wim: 00000002   tbr: 40000890   y: 00000000
    pc:   000063AC  st  %g1, [%g1 + 0x8]
    npc:  00005F68  st  %i4, [%g6 + 0x10]
grmon2> dis
    0=> 0x000063ac: c2206008  st  %g1, [%g1 + 0x8]
        0x000063b0: 92100008  mov  %o0, %o1                <_API_extensions_Add+0>
        0x000063b4: 1110000a  sethi  %hi(0x40002800), %o0  <_API_extensions_Add+4>
        0x000063b8: 901220a0  or  %o0, 0xA0, %o0           <_API_extensions_Add+8>
        0x000063bc: 8213c000  or  %o7, %g1
<_API_extensions_Add+12>
        0x000063c0: 400000c3  call  0x000066CC
<_API_extensions_Add+16>
        0x000063c4: 9e104000  or  %g1, %o7
<_API_extensions_Add+20>
        0x000063c8: 9de3bfa0  save  %sp, -96, %sp
<_API_extensions_Run_postdriver+0>
        0x000063cc: 3910000a  sethi  %hi(0x40002800), %i4
<_API_extensions_Run_postdriver+4>
        0x000063d0: fa0720a0  ld  [%i4 + 0xA0], %i5
<_API_extensions_Run_postdriver+8>
        0x000063d4: b81720a0  or  %i4, 0xA0, %i4
<_API_extensions_Run_postdriver+12>
        0x000063d8: b8072004  add  %i4, 4, %i4
<_API_extensions_Run_postdriver+16>
        0x000063dc: 80a7401c  cmp  %i5, %i4
<_API_extensions_Run_postdriver+20>
        0x000063e0: 02800009  be  0x00006404
<_API_extensions_Run_postdriver+24>
        0x000063e4: 01000000  nop
<_API_extensions_Run_postdriver+28>
        0x000063e8: c2076008  ld  [%i5 + 0x8], %g1
<_API_extensions_Run_postdriver+32>
grmon2> step
grmon2> step
^C
grmon2> bt
   Inside trap/irq
        %pc          %sp
   #0   0x6d1e25c0   0x400ffe78
   #1   0x00005f60   0x400ffee0   <rtems_initialize_data_structures+0x1c>
   #2   0x000003c8   0x400fff40   <boot_card+0x1c>
   #3   0x000001a0   0x400fffa0
   #4   0x00000000   0x40100000
Kind regards,
Mike Looijmans
System Expert
TOPIC Products
Materiaalweg 4, NL-5681 RJ Best
Postbus 440, NL-5680 AK Best
Telefoon: +31 (0) 499 33 69 79
E-mail: mike.looijmans at topicproducts.com
Website: www.topicproducts.com
Please consider the environment before printing this e-mail
