Running RTEMS on a LEON2 from ROM
Mike Looijmans mike.looijmans at topic.nl
Thu Jul 27 05:49:29 UTC 2017
On 27-07-17 07:46, Mike Looijmans wrote:
> On 26-07-17 17:41, Jiri Gaisler wrote:
>> On 07/26/2017 04:17 PM, Jiri Gaisler wrote:
>>> On 07/26/2017 03:24 PM, Mike Looijmans wrote:
>>>> On 26-07-17 13:36, Mike Looijmans wrote:
>>>>> On 26-07-17 13:10, Mike Looijmans wrote:
>>>>>> On 26-07-17 10:21, Jiri Gaisler wrote:
>>>>>>> On 07/26/2017 07:25 AM, Mike Looijmans wrote:
>>>>>>>>> how you do it with standalone sis:
>>>>>>>>> $ sparc-rtems4.12-sis -leon2 application.exe
>>>>>>>>>> hi 100
>>>>>>>>>> go
>>>>>>>>>> hi
>>>>>>>>>> reg
>>>>>>>> Doesn't get very far, there's apparently no (working) memory at
>>>>>>>> 0x40000000 in the simulator, it always reads back as "0", so any
>>>>>>>> access to RAM results in a crash in the simulator.
>>>>>>> Are  you sure you are building sis and gdb from RSB head? sis in the
>>>>>>> regular gdb does not support leon2 yet.
>>>>>>> To advance things, you can send me your application binary and I
>>>>>>> can run
>>>>>>> it in the simulator and send you the traces. If you are on 64-bit
>>>>>>> ubuntu
>>>>>>> 16.04, I can also provide you with binaries for sis/gdb, or the
>>>>>>> whole RSB.
>>>>>> I built the current HEAD of the RSB, and ran using the simulator
>>>>>> from that. The result is the same.
>>>>>> Did some more digging. The problem appears to be that the simulator
>>>>>> populates the memory segments using the VMA values instead of the
>>>>>> LMA values. So it writes the data segment to RAM at 0x40000000,
>>>>>> instead of in ROM, directly following the text segment, as the boot
>>>>>> code expects. I can see the data segment contents there just after
>>>>>> loading the elf.
>>>>>> When the code starts, it copies the data segment from ROM into RAM
>>>>>> and that will copy the empty ROM part onto the RAM, resulting in the
>>>>>> all-zero data in RAM that I see.
>>>>>> Can I load a binary image into sis? (so not an elf but a raw ROM image)
>>>>>> I'll try using objdump to concat the text and data into a single
>>>>>> segment elf for the simulator. Or maybe patch the VMA address to
>>>>>> match the LMA.
>>>>> That worked. According to SIS, the crash happens here:
>>>>> https://git.rtems.org/rtems/tree/cpukit/score/src/heap.c?h=4.11#n274
>>>>>   From sis, i can see:
>>>>>       18156  0000da3c  81c3e008  retl
>>>>>       18158  0000da40  01000000  nop
>>>>>       18159  00006eec  c41fbff8  ldd  [ %fp + -8 ], %g2
>>>>>       18162  00006ef0  b406401a  add  %i1, %i2, %i2
>>>>>       18163  00006ef4  f020a008  st  %i0, [ %g2 + 8 ]
>>>>>       18166  00006ef8  f020a00c  st  %i0, [ %g2 + 0xc ]
>>>>>       18169  00006efc  f4208000  st  %i2, [ %g2 ]
>>>>>       18172  00006f00  8220c002  sub  %g3, %g2, %g1
>>>>>       18173  00006f04  88106001  or  %g1, 1, %g4
>>>>>       18174  00006f08  c820a004  st  %g4, [ %g2 + 4 ]
>>>>>       18177  00006f0c  c43e2020  std  %g2, [ %i0 + 0x20 ]
>>>>>       18181  00006f10  c4262008  st  %g2, [ %i0 + 8 ]
>>>>>       18184  00006f14  c426200c  st  %g2, [ %i0 + 0xc ]
>>>>>       18187  00006f18  f6262010  st  %i3, [ %i0 + 0x10 ]
>>>>>       18190  00006f1c  fa262014  st  %i5, [ %i0 + 0x14 ]
>>>>>       18193  00006f20  f2262018  st  %i1, [ %i0 + 0x18 ]
>>>>>       18196  00006f24  f426201c  st  %i2, [ %i0 + 0x1c ]
>>>>>       18199  00006f28  c220c000  st  %g1, [ %g3 ]
>>>>>       18203  40000090  91d020ff  ta  0xff
>>>>> sis> reg
>>>>>         INS       LOCALS      OUTS     GLOBALS
>>>>>      0:  40002500   91CFE0F0   51CF6D70   00000000
>>>>>      1:  00000000   00006F28   00000008   51CF6D70
>>>>>      2:  00000068   00006F2C   0A39EDAF   40007380
>>>>>      3:  00000010   00000000   00000007   91CFE0F0
>>>>>      4:  400FFE70   00000000   FFFFFFFF   51CF6D71
>>>>>      5:  40002568   00000000   00000008   00000000
>>>>>      6:  400FFE10   00000000   400FFDB0   00000000
>>>>>      7:  00006EE4   00000000   00006DD0   00000000
>>>>>    psr: 00400FC3   wim: 00000002   tbr: 40000090   y: 00000000
>>>>> Looked this address up in the "objdump -S" output, and that shows the
>>>>> following source code and assembly there:
>>>>>     /* Heap control */
>>>>>     heap->page_size = page_size;
>>>>>       6f18:    f6 26 20 10     st  %i3, [ %i0 + 0x10 ]
>>>>>     heap->min_block_size = min_block_size;
>>>>>       6f1c:    fa 26 20 14     st  %i5, [ %i0 + 0x14 ]
>>>>>     heap->area_begin = heap_area_begin;
>>>>>       6f20:    f2 26 20 18     st  %i1, [ %i0 + 0x18 ]
>>>>>     heap->area_end = heap_area_end;
>>>>>       6f24:    f4 26 20 1c     st  %i2, [ %i0 + 0x1c ]
>>>>>     heap->last_block = last_block;
>>>>>     _Heap_Free_list_head( heap )->next = first_block;
>>>>>     _Heap_Free_list_tail( heap )->prev = first_block;
>>>>>     /* Last block */
>>>>>     last_block->prev_size = first_block_size;
>>>>>       6f28:    c2 20 c0 00     st  %g1, [ %g3 ]
>>>>> Something's up with the heap initialization. Haven't found out what
>>>>> exactly though. %g3=91CFE0F0 but should be in the RAM range
>>>>> (400XXXXX) for that "st" to make sense.
>>>> "_Heap_Initialize" is called twice. Once from
>>>> _Workspace_Handler_initialization with sensible values, and the second
>>>> time it's called from RTEMS_Malloc_Initialize, with the heap_end set
>>>> to 0x91CFE0FF which isn't valid and causes the crash.
>>> _Heap_Initialize is called twice, this is normal. However, the SPARC
>>> port has a peculiar way of passing the top of memory, it does that by
>>> writing it to a symbol called rdb_start, which is located at vector
>>> 0x7c  in the trap table. In normal cases, rdb_start is at address
>>> 400007c0. I guess when the trap table is relocated, the value is lost
>>> somehow and overwritten with a assembly instruction.
>>> Normal leon2 executable:
>>> (gdb) p /x rdb_start
>>> $2 = 0x40fffe80
>>> (gdb)
>>> You binary after boot:
>>> $3 = 0x91d020ff
>>> (gdb)
>>> If you recreate the trap table in RAM, make sure that the rdb_start is
>>> properly set to end of RAM.
>>> Jiri.
>> Let me clarify this. The rdb_start is set by either the prom loader,
>> grmon or simulator to the top of available RAM (64-byte aligned), RTEMS
>> then use the value to allocate the stack and heap. So your boot code
>> must write this value before the system starts initializing. If you have
>> 1 Mbyte of RAM, then set 0x400007c0 = 0x400fffe0 and it should work. The
>> reason for this is historical, but it allows the same executable to run
>> on different boards with varying amount of memory.
> Ok, adding ".word RAM_END-16" at that location fixes the crash in the heap init.
> Also printk seems to work now.
> sis> go
> resuming at 0x00000000
> work_area_start = 0x40003540
> work_area_size = 1018496 0x000F8A80
> end = 0x400FBFC0
> current stack pointer = 0x400FFF40
> rdb_start = 0x400FFFC0
> end = 0x400FBFC0
> heap_start = 0x4000737E
> heap_size = 1002562
> Memory exception at 1000014 (illegal address)
> IU in error mode (255)
>      78366  40000090  91d020ff  ta  0xff
> The cause is at 0x8f84, disassembling that points to the
> "_Scheduler_Update_heir" routine, which was called from
> _Scheduler_default_Start_idle
> Some thread object here points at 0x10000000 which is an invalid memory location.
This smells like another "special" trap table entry - 0x1000000000 is the
"nop" instruction, which fills about three quarters of the trap table.
Kind regards,
Mike Looijmans
System Expert
TOPIC Products
Materiaalweg 4, NL-5681 RJ Best
Postbus 440, NL-5680 AK Best
Telefoon: +31 (0) 499 33 69 79
E-mail: mike.looijmans at topicproducts.com
Website: www.topicproducts.com
Please consider the environment before printing this e-mail
