Running RTEMS on a LEON2 from ROM
Mike Looijmans mike.looijmans at topic.nl
Thu Jul 27 12:50:45 UTC 2017
On 27-07-17 13:07, Jiri Gaisler wrote:
> On 07/27/2017 12:23 PM, Jiri Gaisler wrote:
>> On 07/27/2017 07:49 AM, Mike Looijmans wrote:
>>> On 27-07-17 07:46, Mike Looijmans wrote:
>>>> On 26-07-17 17:41, Jiri Gaisler wrote:
>>>>> On 07/26/2017 04:17 PM, Jiri Gaisler wrote:
>>>>>> On 07/26/2017 03:24 PM, Mike Looijmans wrote:
>>>>>>> On 26-07-17 13:36, Mike Looijmans wrote:
>>>>>>>> On 26-07-17 13:10, Mike Looijmans wrote:
>>>>>>>>> On 26-07-17 10:21, Jiri Gaisler wrote:
>>>>>>>>>> On 07/26/2017 07:25 AM, Mike Looijmans wrote:
>>>>>>>>>>>> how you do it with standalone sis:
>>>>>>>>>>>> $ sparc-rtems4.12-sis -leon2 application.exe
>>>>>>>>>>>>> hi 100
>>>>>>>>>>>>> go
>>>>>>>>>>>>> hi
>>>>>>>>>>>>> reg
>>>>>>>>>>> Doesn't get very far, there's apparently no (working) memory at
>>>>>>>>>>> 0x40000000 in the simulator, it always reads back as "0", so any
>>>>>>>>>>> access to RAM results in a crash in the simulator.
>>>>>>>>>> Are  you sure you are building sis and gdb from RSB head? sis
>>>>>>>>>> in the
>>>>>>>>>> regular gdb does not support leon2 yet.
>>>>>>>>>> To advance things, you can send me your application binary and I
>>>>>>>>>> can run
>>>>>>>>>> it in the simulator and send you the traces. If you are on 64-bit
>>>>>>>>>> ubuntu
>>>>>>>>>> 16.04, I can also provide you with binaries for sis/gdb, or the
>>>>>>>>>> whole RSB.
>>>>>>>>> I built the current HEAD of the RSB, and ran using the simulator
>>>>>>>>> from that. The result is the same.
>>>>>>>>> Did some more digging. The problem appears to be that the simulator
>>>>>>>>> populates the memory segments using the VMA values instead of the
>>>>>>>>> LMA values. So it writes the data segment to RAM at 0x40000000,
>>>>>>>>> instead of in ROM, directly following the text segment, as the boot
>>>>>>>>> code expects. I can see the data segment contents there just after
>>>>>>>>> loading the elf.
>>>>>>>>> When the code starts, it copies the data segment from ROM into RAM
>>>>>>>>> and that will copy the empty ROM part onto the RAM, resulting in
>>>>>>>>> the
>>>>>>>>> all-zero data in RAM that I see.
>>>>>>>>> Can I load a binary image into sis? (so not an elf but a raw ROM
>>>>>>>>> image)
>>>>>>>>> I'll try using objdump to concat the text and data into a single
>>>>>>>>> segment elf for the simulator. Or maybe patch the VMA address to
>>>>>>>>> match the LMA.
>>>>>>>> That worked. According to SIS, the crash happens here:
>>>>>>>> https://git.rtems.org/rtems/tree/cpukit/score/src/heap.c?h=4.11#n274
>>>>>>>>    From sis, i can see:
>>>>>>>>        18156  0000da3c  81c3e008  retl
>>>>>>>>        18158  0000da40  01000000  nop
>>>>>>>>        18159  00006eec  c41fbff8  ldd  [ %fp + -8 ], %g2
>>>>>>>>        18162  00006ef0  b406401a  add  %i1, %i2, %i2
>>>>>>>>        18163  00006ef4  f020a008  st  %i0, [ %g2 + 8 ]
>>>>>>>>        18166  00006ef8  f020a00c  st  %i0, [ %g2 + 0xc ]
>>>>>>>>        18169  00006efc  f4208000  st  %i2, [ %g2 ]
>>>>>>>>        18172  00006f00  8220c002  sub  %g3, %g2, %g1
>>>>>>>>        18173  00006f04  88106001  or  %g1, 1, %g4
>>>>>>>>        18174  00006f08  c820a004  st  %g4, [ %g2 + 4 ]
>>>>>>>>        18177  00006f0c  c43e2020  std  %g2, [ %i0 + 0x20 ]
>>>>>>>>        18181  00006f10  c4262008  st  %g2, [ %i0 + 8 ]
>>>>>>>>        18184  00006f14  c426200c  st  %g2, [ %i0 + 0xc ]
>>>>>>>>        18187  00006f18  f6262010  st  %i3, [ %i0 + 0x10 ]
>>>>>>>>        18190  00006f1c  fa262014  st  %i5, [ %i0 + 0x14 ]
>>>>>>>>        18193  00006f20  f2262018  st  %i1, [ %i0 + 0x18 ]
>>>>>>>>        18196  00006f24  f426201c  st  %i2, [ %i0 + 0x1c ]
>>>>>>>>        18199  00006f28  c220c000  st  %g1, [ %g3 ]
>>>>>>>>        18203  40000090  91d020ff  ta  0xff
>>>>>>>> sis> reg
>>>>>>>>          INS       LOCALS      OUTS     GLOBALS
>>>>>>>>       0:  40002500   91CFE0F0   51CF6D70   00000000
>>>>>>>>       1:  00000000   00006F28   00000008   51CF6D70
>>>>>>>>       2:  00000068   00006F2C   0A39EDAF   40007380
>>>>>>>>       3:  00000010   00000000   00000007   91CFE0F0
>>>>>>>>       4:  400FFE70   00000000   FFFFFFFF   51CF6D71
>>>>>>>>       5:  40002568   00000000   00000008   00000000
>>>>>>>>       6:  400FFE10   00000000   400FFDB0   00000000
>>>>>>>>       7:  00006EE4   00000000   00006DD0   00000000
>>>>>>>>     psr: 00400FC3   wim: 00000002   tbr: 40000090   y: 00000000
>>>>>>>> Looked this address up in the "objdump -S" output, and that shows
>>>>>>>> the
>>>>>>>> following source code and assembly there:
>>>>>>>>      /* Heap control */
>>>>>>>>      heap->page_size = page_size;
>>>>>>>>        6f18:    f6 26 20 10     st  %i3, [ %i0 + 0x10 ]
>>>>>>>>      heap->min_block_size = min_block_size;
>>>>>>>>        6f1c:    fa 26 20 14     st  %i5, [ %i0 + 0x14 ]
>>>>>>>>      heap->area_begin = heap_area_begin;
>>>>>>>>        6f20:    f2 26 20 18     st  %i1, [ %i0 + 0x18 ]
>>>>>>>>      heap->area_end = heap_area_end;
>>>>>>>>        6f24:    f4 26 20 1c     st  %i2, [ %i0 + 0x1c ]
>>>>>>>>      heap->last_block = last_block;
>>>>>>>>      _Heap_Free_list_head( heap )->next = first_block;
>>>>>>>>      _Heap_Free_list_tail( heap )->prev = first_block;
>>>>>>>>      /* Last block */
>>>>>>>>      last_block->prev_size = first_block_size;
>>>>>>>>        6f28:    c2 20 c0 00     st  %g1, [ %g3 ]
>>>>>>>> Something's up with the heap initialization. Haven't found out what
>>>>>>>> exactly though. %g3=91CFE0F0 but should be in the RAM range
>>>>>>>> (400XXXXX) for that "st" to make sense.
>>>>>>> "_Heap_Initialize" is called twice. Once from
>>>>>>> _Workspace_Handler_initialization with sensible values, and the
>>>>>>> second
>>>>>>> time it's called from RTEMS_Malloc_Initialize, with the heap_end set
>>>>>>> to 0x91CFE0FF which isn't valid and causes the crash.
>>>>>> _Heap_Initialize is called twice, this is normal. However, the SPARC
>>>>>> port has a peculiar way of passing the top of memory, it does that by
>>>>>> writing it to a symbol called rdb_start, which is located at vector
>>>>>> 0x7c  in the trap table. In normal cases, rdb_start is at address
>>>>>> 400007c0. I guess when the trap table is relocated, the value is lost
>>>>>> somehow and overwritten with a assembly instruction.
>>>>>> Normal leon2 executable:
>>>>>> (gdb) p /x rdb_start
>>>>>> $2 = 0x40fffe80
>>>>>> (gdb)
>>>>>> You binary after boot:
>>>>>> $3 = 0x91d020ff
>>>>>> (gdb)
>>>>>> If you recreate the trap table in RAM, make sure that the rdb_start is
>>>>>> properly set to end of RAM.
>>>>>> Jiri.
>>>>> Let me clarify this. The rdb_start is set by either the prom loader,
>>>>> grmon or simulator to the top of available RAM (64-byte aligned), RTEMS
>>>>> then use the value to allocate the stack and heap. So your boot code
>>>>> must write this value before the system starts initializing. If you
>>>>> have
>>>>> 1 Mbyte of RAM, then set 0x400007c0 = 0x400fffe0 and it should work.
>>>>> The
>>>>> reason for this is historical, but it allows the same executable to run
>>>>> on different boards with varying amount of memory.
>>>> Ok, adding ".word RAM_END-16" at that location fixes the crash in the
>>>> heap init.
>>>> Also printk seems to work now.
>>>> sis> go
>>>> resuming at 0x00000000
>>>> work_area_start = 0x40003540
>>>> work_area_size = 1018496 0x000F8A80
>>>> end = 0x400FBFC0
>>>> current stack pointer = 0x400FFF40
>>>> rdb_start = 0x400FFFC0
>>>> end = 0x400FBFC0
>>>> heap_start = 0x4000737E
>>>> heap_size = 1002562
>>>> Memory exception at 1000014 (illegal address)
>>>> IU in error mode (255)
>>>>       78366  40000090  91d020ff  ta  0xff
>>>> The cause is at 0x8f84, disassembling that points to the
>>>> "_Scheduler_Update_heir" routine, which was called from
>>>> _Scheduler_default_Start_idle
>>>> Some thread object here points at 0x10000000 which is an invalid
>>>> memory location.
>>> This smells like another "special" trap table entry - 0x1000000000 is
>>> the "nop" instruction, which fills about three quarters of the trap
>>> table.
>> This is probably a problem in your start.S . register %g6 contains
>> per-CPU information and is set early in booting in start.S:
>>   292         sethi   %hi(_Per_CPU_Information), %g6 ! get per-CPU control
>>   293         add     %g6, %lo(_Per_CPU_Information), %g6
>> The value of %g6 in your code is 0x000F4C79, ie points to PROM rather
>> than RAM. Check your start.S and make sure %g6 is setup correctly.
> I saw in your hello.num that _Per_CPU_Information should be 0x40003000.
> I assigned this value to %g6 before execution and now the program runs
> to end:
> *** BEGIN OF TEST HELLO WORLD ***
> Hello World
> *** END OF TEST HELLO WORLD ***
> This looks good, just fix the start.S to set %g6 and you should have a
> working binary..! Meanwhile, I will fix the VMA/LVA problem in sis -
> thanks for spotting this...
Ah, indeed. Setting that magic %g6 register got lost while moving things
around for ROM boot.
I added a "set _Per_CPU_Information, %g6" prior to the card_boot call, and now
the hello program runs okay in simulation.
Tried on target, using "grmon2 -leon2 -ni -u". There it only works if i "run
0", press ctrl-C within a second or so, and then "cont". Without breaking, it
just sits there, and if I ctrl-C after a minute or so, it just says "program
terminated normally". But at least it stopped crashing...
If you're interested, this is the current state:
https://github.com/topic-embedded-products/rtems/commits/bsp-miamil2
Kind regards,
Mike Looijmans
System Expert
TOPIC Products
Materiaalweg 4, NL-5681 RJ Best
Postbus 440, NL-5680 AK Best
Telefoon: +31 (0) 499 33 69 79
E-mail: mike.looijmans at topicproducts.com
Website: www.topicproducts.com
Please consider the environment before printing this e-mail
