Out of the box Ada support
Sebastian Huber
Wed Jun 14 09:32:04 UTC 2017
Hello,
as a side-effect of the move of some POSIX header files from RTEMS to
Newlib it is now possible to create the Ada compiler with the normal
tool chain build. Ada is available on all RTEMS targets that support
thread-local storage (TLS). This is currently ARM, PowerPC, SPARC, m68k
and x86. To build a tool chain with Ada support use the RSB, for example:
../source-builder/sb-set-builder --prefix=/opt/rtems-4.12 4.12/rtems-arm
--with-ada
This yields:
arm-rtems4.12-gnat --version
GNAT 7.1.0 20170502 (RTEMS 4.12, RSB
0ba8934976c2821d76ad770c633da85d99b53e2c, Newlib 2.5.0.20170519)
Copyright (C) 1996-2017, Free Software Foundation, Inc.
This is free software; see the source for copying conditions.
There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE.
You need a native GNAT installed to build the Ada compiler. You have to
delete the build directory of the RSB before you start with the new tool
chain build due to https://devel.rtems.org/ticket/3048.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
