How to make a rtems kernel shell prompt to qemu console?
Sun Jun 25 23:25:07 UTC 2017
On 23/06/2017 19:19, Cillian O'Donnell wrote:
> On 23 June 2017 at 09:37, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> Hello,
>> this worked for me last week or so:
>> qemu-system-i386 -monitor null -nographic -serial stdio -nodefaults -kernel
>> ticker.exe
> Ok, with slightly different options hello.exe failed to produce any
> output. With Sebastian's options above, it just hangs after the output
> and fails to exit automatically like a few of the others I tested
> which shouldn't cause you any trouble so nevermind.
> Jaeho, have you been able to run any of the samples to check
> everything is working correctly before you try your own program?
I think different hosts may require different option sets and that may be
creating some confusion.
