Dynamic load real-time tasks
Павел Жданов
paul.alex.zhdanov at gmail.com
Wed Jun 28 10:03:26 UTC 2017
> > Have you loaded a symbol table for the base image that contains the
> 'printf'
> > function.
> > I created it but symbols are all undefined. Is it OK?
> Did you load the symbol table on to the target somehow?
I quess I didn't load it.
At the moment I try to modify dl01 example to load dl-o1.o from filesystem.
My Makefile:
all:
i386-rtems4.11-gcc -B$(RTEMS_MAKEFILE_PATH)lib/ -specs bsp_specs
-qrtems -mtune=i486 -O2 -g -Wall -Wmissing-prototypes
-Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -MT
filesystem.o -MD -MP -MF .deps/filesystem.Tpo *-c -o filesystem.o
filesystem.c*
i386-rtems4.11-gcc -B../../../../../pc486/lib/ -specs bsp_specs -qrtems
-DHAVE_CONFIG_H -I.
-I../../../../../../../c/src/../../testsuites/libtests/dl01 -I..
-I../../../../../../../c/src/../../testsuites/libtests/../support/include
dl-o1.o -MD -MP -MF .deps/dl-o1.Tpo *-c -o dl-o1.o dl-o1.c*
-DHAVE_CONFIG_H -I.
init.o -MD -MP -MF .deps/init.Tpo *-c -o init.o init.c*
-DHAVE_CONFIG_H -I.
dl-load.o -MD -MP -MF .deps/dl-load.Tpo *-c -o dl-load.o dl-load.c*
-Wl,-Ttext,0x00100000 -mtune=i486 *-o dl01.pre.exe init.o dl-load.o
dl-o1.o filesystem.o*
mv dl01.pre.exe dl01.pre
rtems-syms -e -c "-mtune=i486 -O2 -g -Wall -Wmissing-prototypes
-Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs" *-o
dl-sym.o dl01.pre*
-Wl,-Ttext,0x00100000 -mtune=i486 *-o dl01.exe init.o dl-load.o dl-o1.o
dl-sym.o filesystem.o*
filesystem.c contains functions to mount dos partition.
The output is:
dlopen failed: duplicate global symbol: rtems_main
URL: <http://lists.rtems.org/pipermail/users/attachments/20170628/0100f833/attachment.html>
