[GSoC] Ethernet support for beaglebone.
Ben Gras
beng at shrike-systems.com
Fri Mar 10 20:58:12 UTC 2017
On 03/10/2017 03:50 PM, Ketul Shah wrote:
> Hi Nikolay and all,
> Glad to see your interest ...!
> On 9 March 2017 at 15:24, Nikolay Komashinskiy
> <nikolay.komashinskiy at yandex.ru
> <mailto:nikolay.komashinskiy at yandex.ru>> wrote:
> I think Ethernet mostly works on BB's. There were some performance
> issues at one point
>> related to UBoot version. It was like a 10x difference. I think
>> it was narrowed down to
>> the initialization of the cache or MMU being different.
>> I have cc'ed Ben Gras.He is more likely to remember the details.
>> --joel
>> users mailing list
>> users at rtems.org <mailto:users at rtems.org>
>> <http://lists.rtems.org/mailman/listinfo/users>
> I also found that there is a gpio code for beaglebone. These
> peripherals are interested for me
> because in the future I want to implement a distributed real-time
> system - that would be hard to do
> without ethernet (afaik am335x supports IEEE 1588v2 protocol).
> So, could you tell me what is the current state of ethernet and gpio?
> And I still can't understand do I need a jtag in order to debug
> rtems on top of beagleboard?
> users mailing list
> Me and my friend Ragunath worked on GPIO and Networking ( Ethernet
> driver) in GSoC'15.
> I also cc'ed Ragu. He would be the right person to guide you out for
> Ethernet driver.
> Also last year Punit worked on PWM driver...
> You can refer to following links :-
> 1. http://ragustechblog.blogspot.in/2015/06/gsoc-2015.html
> 2. https://github.com/ketul93/RTEMS-on-BBB
> Also for debug method we generally use printf statements in code and
> debug using serial utilities (ex. picocom) using UART communication.
> For better debugging yes you would need JTAG ...
Thanks for your input Ketul.
I totally agree that printf is usually enough. That does require a
'special' cable (serial TTL logic levels to usb) but is worth it. JTAG
also requires a
special cable.
If you can, consider a beaglebone white - it has the UART and JTAG on
the regular USB port (the one it already takes power from), an ideal
development board with the same SOC as the BBB.
URL: <http://lists.rtems.org/pipermail/users/attachments/20170310/8e4e8554/attachment.html>
