RTEMS Source Builder problem
Karim, Hassan
hassan.karim at bison.howard.edu
Sun Mar 12 15:32:43 UTC 2017
To build from scratch the following should get you get all of the required
libs/packages except networking (seperate process for that):
> *sudo apt-get install **git autoconf automake bison binutils gcc g++ gdb
> texinfo unzip make flex ncurses-dev python-dev zlib1g-dev*
Regards,
*Hassan Karim, CISSP*
https://www.linkedin.com/in/hassankarimcissp
Comp Sci Ph.D. Student
Howard University
(202) 569-1012
On Sun, Mar 12, 2017 at 8:44 AM, Piotr Sykulski <pitersk at gmail.com> wrote:
> It worked. Thank you!
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20170312/987cd712/attachment.html>
