No sparc build set file found
Cillian Patrick O Donnell cillian.odonnell42 at mail.dcu.ie
Mon Mar 13 08:27:37 UTC 2017
Hi,
I'm trying to build the toolset with RSB and I am getting the error.
error: no build set file found: 4.11/rtems-sparc.bset
The log generated is:
RTEMS Source Builder - Set Builder, 4.12 (10d9e2dfacf7 modified)
 Command Line: source-builder/sb-set-builder --log=l-sparc.txt
--prefix=/home/cpod/development/rtems/4.11 4.11/rtems-sparc
 Python: 2.7.12 (default, Nov 19 2016, 06:48:10) [GCC 5.4.0 20160609]
Build Set: 4.11/rtems-sparc
Build Set: Time 0:00:00.000150
When listing the build sets with --list-bsets only bare/config shows
results.
Examining: config
Examining: source-builder/config
Examining: bare/config
    devel/autotools-base.bset
    devel/autotools-internal.bset
    devel/autotools.bset
    devel/dtc.bset
    devel/libtool.bset
    devel/libusb.bset
    devel/or1ksim.bset
    devel/qemu.bset
    gnu-tools-4.6.bset
    gnu-tools-4.8.2.bset
    lang/gcc491.bset
There seems to be only .cfg files in source-builder/config. No .bset
I deleted everything and started again.
git clone git://git.rtems.org/rtems-source-builder.git
Same problem, no .bset in source-builder/config.
Any help would be much appreciated.
Thanks.
*Séanadh Ríomhphoist/Email DisclaimerTá an ríomhphost seo agus aon chomhad
a sheoltar leis faoi rún agus is lena úsáid ag an seolaí agus sin amháin
é. Is féidir tuilleadh a léamh anseo.
<https://www4.dcu.ie/iss/seanadh-riomhphoist.shtml>
<https://www4.dcu.ie/iss/seanadh-riomhphoist.shtml>This e-mail and any
files transmitted with it are confidential and are intended solely for use
by the addressee. Read more here.
<https://www4.dcu.ie/iss/email-disclaimer.shtml> *
URL: <http://lists.rtems.org/pipermail/users/attachments/20170313/be7163bf/attachment-0001.html>
