No sparc build set file found
Mon Mar 13 22:25:32 UTC 2017
On 13/03/2017 23:10, Piotr Sykulski wrote:
> For more information check https://docs.rtems.org/rsb/ .
Please use the latest version of the documentation found at
https://docs.rtems.org/ and the RSB which is
https://docs.rtems.org/branches/master/rsb/index.html
The doco at the link you provided is old and will be removed.
Thanks
