No sparc build set file found
Mon Mar 13 22:29:22 UTC 2017
On 13/03/2017 23:25, Piotr Sykulski wrote:
> You have to run source builder from a different folder. .bsets are
> located in config folder but they are in
> rtems-source-builder/rtems/config/4.12 not in
> rtems-source-builder/source-builder/config
> Have a look here
> https://github.com/RTEMS/rtems-source-builder/tree/master/rtems/config/4.12
Correct and thanks.
You can create a config directory any where even outside the RSB source
tree and the RSB will build it. In the RSB source tree there is the RSB
source under source-builder and then support for RTEMS under 'rtems' and
support for bare host packages under 'bare'. The RSB maintains a path it
searches for configuration files and this include the 'config' directory
under source-builder. That directory hold common configurations that can
be shared.
