A problem of rtems build
libing403
libing18934721626 at gmail.com
Tue Mar 14 01:16:09 UTC 2017
hi,
thank Joel.
I have tried .There are many rtems tools in the folder ~/development/rtems/4
.12,such as
arm-rtems,i386-rtems,....
I put i386-rtems tools in PATH before build i386 bsp
$export PATH=$HOME/development/rtems/4.12/i386-rtems/bin:$PATH
$ export PATH=$HOME/development/rtems/4.12/bin:$PATH
and the same problem .
Regards,
LiBing
2017-03-14 9:02 GMT+08:00 Joel Sherrill <joel at rtems.org>:
> On Mar 13, 2017 7:26 PM, "libing403" <libing18934721626 at gmail.com> wrote:
> hello
> I have looked at the steps documented here: https://docs.rtems.org/b
> ranches/master/user/start/index.html
> Something different is I ran RSB for the “all.bset” , which contain
> seventeen architectures.
> I do this and succeed:
> (1)Rtems source Build
> $ sudo apt-get build-dep binutils gcc g++ gdb unzip git python2.7-dev
> $ cd
> $ mkdir -p development/rtems/src
> $ cd development/rtems/src
> $ git clone git://git.rtems.org/rtems-source-builder.git
> $ cd rtems-source-builder
> $ source-builder/sb-check
> RTEMS Source Builder environment is ok
> $ cd rtems
> $ ../source-builder/sb-set-builder --log=l-all.txt \
> --prefix=$HOME/development/rtems/4.12 4.12/rtems-all
> I do this and something error:
> (2)Rtems build
> $ cd ~/development/rtems/src
> $ git clone git://git.rtems.org/rtems.git
> $ cd rtems
> $ ./bootstrap
> tm34/Makefile.am:3: warning: source file '../tm03/task1.c' is in a
> subdirectory,
> tm34/Makefile.am:3: but option 'subdir-objects' is disabled
> tm34/Makefile.am:3: warning: source file '../../support/src/tmtests_empty_function.c'
> is in a subdirectory,
> tm35/Makefile.am:3: warning: source file '../tm02/task1.c' is in a
> subdirectory,
> tm35/Makefile.am:3: but option 'subdir-objects' is disabled
> tm35/Makefile.am:3: warning: source file '../../support/src/tmtests_empty_function.c'
> tmtests/tm28/Makefile.am:7: warning: source file '../../support/init.c' is
> in a subdirectory,
> tmtests/tm28/Makefile.am:7: but option 'subdir-objects' is disabled
> tmtests/tm29/Makefile.am:7: warning: source file '../../support/init.c' is
> in a subdirectory,
> tmtests/tm29/Makefile.am:7: but option 'subdir-objects' is disabled
> tmtests/tmck/Makefile.am:7: warning: source file '../../support/init.c' is
> in a subdirectory,
> tmtests/tmck/Makefile.am:7: but option 'subdir-objects' is disabled
> tmtests/tmoverhd/Makefile.am:7: warning: source file
> '../../support/init.c' is in a subdirectory,
> These messages are not right. My suspicion is that you are using the
> autoconf and automake from your distribution. You need to put the rtems
> tools first in your PATH.
> $../rtems/configure \
> --prefix=`pwd`/../rtems_i386 \
> --target=i386-rtems4.12 \
> --enable-posix \
> --enable-networking \
> --enable-tests \
> --enable-rdbg \
> --enable-rtemsbsp="pc386"
> checking for a thread-safe mkdir -p... /bin/mkdir -p
> checking for gawk... no
> checking for mawk... mawk
> checking whether make sets $(MAKE)... yes
> checking whether make supports nested variables... yes
> checking whether to enable maintainer-specific portions of Makefiles... no
> checking that generated files are newer than configure... done
> configure: creating ./config.status
> config.status: creating Makefile
> target architecture: i386.
> available BSPs: pc386.
> 'make all' will build the following BSPs: pc386.
> other BSPs can be built with 'make RTEMS_BSP="bsp1 bsp2 ..."'
> $make
> Making all in testsuites/tools
> make[1]: 正在进入目录 `/home/libing403/development/r
> tems/src/i386-rtems-build/testsuites/tools'
> Making all in generic
> make[2]: 正在进入目录 `/home/libing403/development/r
> tems/src/i386-rtems-build/testsuites/tools/generic'
> make[2]: 没有什么可以做的为 `all'。
> make[2]:正在离开目录 `/home/libing403/development/r
> make[2]: 没有什么可以做的为 `all-am'。
> make[1]:正在离开目录 `/home/libing403/development/r
> Making all in i386-rtems4.12/c
> tems/src/i386-rtems-build/i386-rtems4.12/c'
> Making all in .
> Making all in pc386
> tems/src/i386-rtems-build/i386-rtems4.12/c/pc386'
> make[2]: *** 没有规则可以创建目标“all”。 停止。
> make[1]: *** [all-recursive] 错误 1
> make: *** [all-recursive] 错误 1
> $~/development/rtems/src/rtems$ ./rtems-bsps
> RTEMS 4.12
> Architectures: 17
> BSP Count: 172
> arm:
> altcycv_devkit c/src/lib/libbsp/arm/altera-cyclone-v
> altcycv_devkit_smp c/src/lib/libbsp/arm/altera-cyclone-v
> atsamv c/src/lib/libbsp/arm/atsam
> beagleboardorig c/src/lib/libbsp/arm/beagle
> beagleboardxm c/src/lib/libbsp/arm/beagle
> beagleboneblack c/src/lib/libbsp/arm/beagle
> beaglebonewhite c/src/lib/libbsp/arm/beagle
> csb336 c/src/lib/libbsp/arm/csb336
> csb337 c/src/lib/libbsp/arm/csb337
> I would be grateful for any tips.
> Regards,
> LiBing
> 2017-03-13 20:30 GMT+08:00 Tanu Hari Dixit <tokencolour at gmail.com>:
>> Hi LiBing,
>> What exactly was the error?
>> Did you run configure command after bootstrapping?
>> You can consider looking at the steps documented here:
>> https://docs.rtems.org/branches/master/user/start/index.html
>> Regards,
>> Tanu Hari Dixit.
>> On Mon, Mar 13, 2017 at 5:46 PM, libing403 <libing18934721626 at gmail.com>
>> wrote:
>>> Hello,
>>> I have ran the Rtems Source Builder with "all.bset" that contain
>>> seventeen architectures. it took about 12 hours and succeed.
>>> what I need to do after that? could I begin to build the Rtems .
>>> But when I build the Rtems ,there are many errors.
>>> The command line that I used are following:
>>> $ cd
>>> $ cd rtems
>>> (2)Rtems build
>>> $ cd rtems
>>> $ ./bootstrap
>>> After ran this command line , there are many warning, and ran
>>> $make
>>> Error occurred
>>> Regards,
>>> LiBing
>>> users mailing list
>>> users at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/users
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20170314/2e8ebfdc/attachment-0001.html>
