A problem of rtems build
Joel Sherrill
joel at rtems.org
Tue Mar 14 18:38:00 UTC 2017
On Mon, Mar 13, 2017 at 8:16 PM, libing403 <libing18934721626 at gmail.com>
wrote:
> hi,
> thank Joel.
> I have tried .There are many rtems tools in the folder ~
> /development/rtems/4.12,such as
> arm-rtems,i386-rtems,....
> I put i386-rtems tools in PATH before build i386 bsp
> $export PATH=$HOME/development/rtems/4.12/i386-rtems/bin:$PATH
> $ export PATH=$HOME/development/rtems/4.12/bin:$PATH
> and the same problem .
Try "type autoconf" or "which autoconf" just to make sure.
And the first directory you added to your PATH, shouldn't have been added.
It is
an internal GNU tools directory.
--joel
> Regards,
> LiBing
> 2017-03-14 9:02 GMT+08:00 Joel Sherrill <joel at rtems.org>:
>> On Mar 13, 2017 7:26 PM, "libing403" <libing18934721626 at gmail.com> wrote:
>> hello
>> I have looked at the steps documented here: https://docs.rtems.org/b
>> ranches/master/user/start/index.html
>> Something different is I ran RSB for the “all.bset” , which contain
>> seventeen architectures.
>> I do this and succeed:
>> (1)Rtems source Build
>> $ sudo apt-get build-dep binutils gcc g++ gdb unzip git python2.7-dev
>> $ cd
>> $ mkdir -p development/rtems/src
>> $ cd development/rtems/src
>> $ git clone git://git.rtems.org/rtems-source-builder.git
>> $ cd rtems-source-builder
>> $ source-builder/sb-check
>> RTEMS Source Builder environment is ok
>> $ cd rtems
>> $ ../source-builder/sb-set-builder --log=l-all.txt \
>> --prefix=$HOME/development/rtems/4.12 4.12/rtems-all
>> I do this and something error:
>> (2)Rtems build
>> $ cd ~/development/rtems/src
>> $ git clone git://git.rtems.org/rtems.git
>> $ cd rtems
>> $ ./bootstrap
>> tm34/Makefile.am:3: warning: source file '../tm03/task1.c' is in a
>> subdirectory,
>> tm34/Makefile.am:3: but option 'subdir-objects' is disabled
>> tm34/Makefile.am:3: warning: source file '../../support/src/tmtests_empty_function.c'
>> is in a subdirectory,
>> tm35/Makefile.am:3: warning: source file '../tm02/task1.c' is in a
>> subdirectory,
>> tm35/Makefile.am:3: but option 'subdir-objects' is disabled
>> tm35/Makefile.am:3: warning: source file '../../support/src/tmtests_empty_function.c'
>> tmtests/tm28/Makefile.am:7: warning: source file '../../support/init.c'
>> tmtests/tm28/Makefile.am:7: but option 'subdir-objects' is disabled
>> tmtests/tm29/Makefile.am:7: warning: source file '../../support/init.c'
>> tmtests/tm29/Makefile.am:7: but option 'subdir-objects' is disabled
>> tmtests/tmck/Makefile.am:7: warning: source file '../../support/init.c'
>> tmtests/tmck/Makefile.am:7: but option 'subdir-objects' is disabled
>> tmtests/tmoverhd/Makefile.am:7: warning: source file
>> '../../support/init.c' is in a subdirectory,
>> These messages are not right. My suspicion is that you are using the
>> autoconf and automake from your distribution. You need to put the rtems
>> tools first in your PATH.
>> $../rtems/configure \
>> --prefix=`pwd`/../rtems_i386 \
>> --target=i386-rtems4.12 \
>> --enable-posix \
>> --enable-networking \
>> --enable-tests \
>> --enable-rdbg \
>> --enable-rtemsbsp="pc386"
>> checking for a thread-safe mkdir -p... /bin/mkdir -p
>> checking for gawk... no
>> checking for mawk... mawk
>> checking whether make sets $(MAKE)... yes
>> checking whether make supports nested variables... yes
>> checking whether to enable maintainer-specific portions of Makefiles... no
>> checking that generated files are newer than configure... done
>> configure: creating ./config.status
>> config.status: creating Makefile
>> target architecture: i386.
>> available BSPs: pc386.
>> 'make all' will build the following BSPs: pc386.
>> other BSPs can be built with 'make RTEMS_BSP="bsp1 bsp2 ..."'
>> $make
>> Making all in testsuites/tools
>> make[1]: 正在进入目录 `/home/libing403/development/r
>> tems/src/i386-rtems-build/testsuites/tools'
>> Making all in generic
>> make[2]: 正在进入目录 `/home/libing403/development/r
>> tems/src/i386-rtems-build/testsuites/tools/generic'
>> make[2]: 没有什么可以做的为 `all'。
>> make[2]:正在离开目录 `/home/libing403/development/r
>> make[2]: 没有什么可以做的为 `all-am'。
>> make[1]:正在离开目录 `/home/libing403/development/r
>> Making all in i386-rtems4.12/c
>> tems/src/i386-rtems-build/i386-rtems4.12/c'
>> Making all in .
>> Making all in pc386
>> tems/src/i386-rtems-build/i386-rtems4.12/c/pc386'
>> make[2]: *** 没有规则可以创建目标“all”。 停止。
>> make[1]: *** [all-recursive] 错误 1
>> make: *** [all-recursive] 错误 1
>> $~/development/rtems/src/rtems$ ./rtems-bsps
>> RTEMS 4.12
>> Architectures: 17
>> BSP Count: 172
>> arm:
>> altcycv_devkit c/src/lib/libbsp/arm/altera-cyclone-v
>> altcycv_devkit_smp c/src/lib/libbsp/arm/altera-cyclone-v
>> atsamv c/src/lib/libbsp/arm/atsam
>> beagleboardorig c/src/lib/libbsp/arm/beagle
>> beagleboardxm c/src/lib/libbsp/arm/beagle
>> beagleboneblack c/src/lib/libbsp/arm/beagle
>> beaglebonewhite c/src/lib/libbsp/arm/beagle
>> csb336 c/src/lib/libbsp/arm/csb336
>> csb337 c/src/lib/libbsp/arm/csb337
>> I would be grateful for any tips.
>> Regards,
>> LiBing
>> 2017-03-13 20:30 GMT+08:00 Tanu Hari Dixit <tokencolour at gmail.com>:
>>> Hi LiBing,
>>> What exactly was the error?
>>> Did you run configure command after bootstrapping?
>>> You can consider looking at the steps documented here:
>>> https://docs.rtems.org/branches/master/user/start/index.html
>>> Regards,
>>> Tanu Hari Dixit.
>>> On Mon, Mar 13, 2017 at 5:46 PM, libing403 <libing18934721626 at gmail.com>
>>> wrote:
>>>> Hello,
>>>> I have ran the Rtems Source Builder with "all.bset" that contain
>>>> seventeen architectures. it took about 12 hours and succeed.
>>>> what I need to do after that? could I begin to build the Rtems .
>>>> But when I build the Rtems ,there are many errors.
>>>> The command line that I used are following:
>>>> $ cd
>>>> $ cd rtems
>>>> (2)Rtems build
>>>> $ cd rtems
>>>> $ ./bootstrap
>>>> After ran this command line , there are many warning, and ran
>>>> $make
>>>> Error occurred
>>>> Regards,
>>>> LiBing
>>>> _______________________________________________
>>>> users mailing list
>>>> users at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/users
>> users mailing list
>> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20170314/4c597aa2/attachment-0001.html>
