Any users of the Termios receive/send callbacks?
Pavel Pisa ppisa4lists at pikron.com
Mon Mar 20 09:38:08 UTC 2017
Hello Sebastian,
On Thursday 23 of February 2017 07:51:13 Sebastian Huber wrote:
> Hello,
> the RTEMS Termios implementation provides receive and send callbacks:
> https://git.rtems.org/rtems/tree/cpukit/libcsupport/include/rtems/termiosty
>pes.h#n41
> There is no API to install these callbacks. They are not used in the
> RTEMS code base. Is there someone how uses this stuff? I would like to
> change the invocation conditions to use them for the poll(), select()
> and kqueue() support.
it would be great. Would it work with bare RTEMS or libbsd
would be required? If it can be used without libbsd
on memory constrained systems then it would be great.
Best wishes,
Pavel
PS: I try to re-catch a little with RTEMS posts if I need
    to spent more time by travelling this week.
