RTEMS 4.11.2-rc1 Release
Fri Mar 24 06:40:32 UTC 2017
Hello,
RTEMS 4.11.2-rc1 is available for testing. If you are using RTEMS 4.11.1
we encourage you to test and report any issues before the release date
of 30th March 2017.
The release is available here:
  https://ftp.rtems.org/pub/rtems/releases/4.11/rc/4.11.2-rc1/
The release notes contain the issues fixed. The DOSFS fixes are important.
If you find an issue please raise a ticket and set the milestone to 4.11.2.
If you have a question please email this list.
Notes:
1. This release contains release notes for all 4.11 dot releases. The
PDF has links in red to RTEMS's Trac so you can click though to Trac to
review details.
2. Doxygen documentation may be available for the release date if #2950
can be resolved in time. Another RC containing doxygen will be cut if
fixed in time.
3. The 4.11.3 milestone has been created in Trac with a release date of
29th June 2017 which is around 3 months way. A release will happen if
there are tickets that warrant a dot point release at that time or
sooner depending on the severity of issues reported.
Thanks
