Posix priority vs. RTEMS priority (Sebastian Huber)
    Heinz Junkes
    junkes at fhi-berlin.mpg.de
    Fri Mar 31 18:22:47 UTC 2017
Hello Sebastian,
thank you for your answer. In the RTEMS Manual you can read
that the initialization task should run at Maximum Priority (Classic API).
(which sounds reasonable)
If then the POSIX_Init should also be startet at that level -> POSIX prio 254?
Instead of the low prio “2” ?
Heinz
23.8.5 Specifying Classic API Initialization Task Priority
CONSTANT:
CONFIGURE_INIT_TASK_PRIORITY
DATA TYPE:
RTEMS Task Priority (rtems_task_priority).
RANGE:
One (1) to CONFIGURE_MAXIMUM_PRIORITY.
DEFAULT VALUE:
The default value is 1, which is the highest priority in the Classic API.
DESCRIPTION:
CONFIGURE_INIT_TASK_PRIORITY is the initial priority of the single initialization task defined by the Classic API Initialization Tasks Table.
NOTES:
None.
Fritz-Haber-Institut    | Phone:         (+49 30) 8413-4270
Heinz Junkes             | Fax (G3+G4):   (+49 30) 8413-5900
Faradayweg 4-6        |
D - 14195 Berlin        | E-Mail:     junkes at fhi-berlin.mpg.de
On 31 March 2017 at 14:00:13, users-request at rtems.org (users-request at rtems.org) wrote:
Send users mailing list submissions to
users at rtems.org
To subscribe or unsubscribe via the World Wide Web, visit
http://lists.rtems.org/mailman/listinfo/users
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
users-owner at rtems.org
When replying, please edit your Subject line so it is more specific
than "Re: Contents of users digest..."
Today's Topics:
1. Posix priority vs. RTEMS priority (Heinz Junkes)
2. Re: Posix priority vs. RTEMS priority (Sebastian Huber)
Message: 1
Date: Thu, 30 Mar 2017 15:16:48 +0200
To: "=?utf-8?Q?rtems-users=40rtems.org?=" <users at rtems.org>
Subject: Posix priority vs. RTEMS priority
Message-ID: <etPan.58dd0540.1c44c80b.89fd at fhi-berlin.mpg.de>
Content-Type: text/plain; charset="utf-8"
Dear list,
I?m a bit confused about the priorities used with POSIX in ?RTEMS 4.12.
In the system config I am using the POSIX initialization:
extern void *EPICS_WITH_POSIX_Init(void *argument);
#define CONFIGURE_POSIX_INIT_THREAD_TABLE
#define CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT EPICS_WITH_POSIX_Init
Requesting the task priority in EPICS_WITH_POSIX_Init() I get Prio ?2? whitch looks like ?RTEMS_HIGH_PRIO? ?
void *
EPICS_WITH_POSIX_Init (void *argument)
?int policy;
? ? struct sched_param param;
? ? if (pthread_getschedparam(pthread_self(), &policy, ¶m) != 0)
? ? ? delayedPanic("pthread_getschedparam failed?);
? ? printf(" main priority = %d\n", param.sched_priority);
leads to the output:
?main priority = 2
***** RTEMS Version: rtems-4.11.99.0 (PowerPC/Generic (classic FPU)/beatnik) *****
I expected Prio 254 or 253 because at Posix higher priorities -> higher value.
What do I think wrong here?
Heinz
URL: <http://lists.rtems.org/pipermail/users/attachments/20170330/377614c0/attachment-0001.html>
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20170330/377614c0/attachment-0001.bin>
Message: 2
Date: Fri, 31 Mar 2017 06:51:02 +0200
From: Sebastian Huber <sebastian.huber at embedded-brains.de>
To: Heinz Junkes <junkes at fhi-berlin.mpg.de>, "rtems-users at rtems.org"
Subject: Re: Posix priority vs. RTEMS priority
Message-ID: <58DDE036.3030809 at embedded-brains.de>
Content-Type: text/plain; charset=windows-1252; format=flowed
Hello Heinz,
the POSIX initialization threads are created with the default priority
value (_POSIX_Threads_Default_attributes) which is POSIX 2. You can map
a POSIX priority to the RTEMS priority via:
static int get_current_prio( pthread_t thread )
rtems_status_code sc;
rtems_task_priority prio;
int max;
sc = rtems_task_set_priority( thread, RTEMS_CURRENT_PRIORITY, &prio );
rtems_test_assert( sc == RTEMS_SUCCESSFUL );
max = sched_get_priority_max( SCHED_FIFO );
return max + 1 - (int) prio;
On 30/03/17 15:16, Heinz Junkes wrote:
> Dear list,
> I?m a bit confused about the priorities used with POSIX in RTEMS 4.12.
> void *
> int policy;
> main priority = 2
> FPU)/beatnik) *****
> higher value.
> Heinz
> users mailing list
> users at rtems.org
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
Diese Nachricht ist keine gesch?ftliche Mitteilung im Sinne des EHUG.
Subject: Digest Footer
users mailing list
users at rtems.org
End of users Digest, Vol 126, Issue 36
URL: <http://lists.rtems.org/pipermail/users/attachments/20170331/ca39d6e1/attachment.html>
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20170331/ca39d6e1/attachment.bin>
