GSoC with Beaglebone BSP and my problem
Angelo Fraietta newsgroups at smartcontroller.com.au
Tue Mar 7 22:16:33 UTC 2017
This is what I did, but that was a few years ago. Let me know how it goes
for you.
On Wed, Mar 8, 2017 at 8:55 AM, Nikolay Komashinskiy <
nikolay.komashinskiy at yandex.ru> wrote:
> 07.03.2017, 23:03, "Alexey Dyachenko" <alexey.dyachenko at inbox.ru>:
>   Dear Nikolay,
> would you please check, if you create and change your working directory to
> build  your BSP, as mentioned in  manual, before running configure?
> See example below for erc32:
> $ mkdir erc32
> $ cd erc32
> $ $HOME/development/rtems/kernel/rtems/configure --prefix*=*$HOME
> /development/rtems/4.12
>    \--target*=*sparc-rtems4.12 --enable-rtemsbsp*=*erc32 --enable-posix
> Regards, Alexey
> I have built it - I repeated the building process and programs were built.
> I think that something wrong
> was in my previous attempt, so the environment became dirty (as error
> meessage mentioned).
> Though, samples are built now, I have no output running them in
> arm-rtems4.12-gdb.
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20170308/b8292dcf/attachment-0002.html>
Type: application/vnd.openxmlformats-officedocument.wordprocessingml.document
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20170308/b8292dcf/attachment-0002.bin>
