GSoC with Beaglebone BSP and my problem
Joel Sherrill
joel at rtems.org
Wed Mar 15 20:07:41 UTC 2017
On Tue, Mar 7, 2017 at 3:55 PM, Nikolay Komashinskiy <
nikolay.komashinskiy at yandex.ru> wrote:
> 07.03.2017, 23:03, "Alexey Dyachenko" <alexey.dyachenko at inbox.ru>:
> Dear Nikolay,
> would you please check, if you create and change your working directory to
> build your BSP, as mentioned in manual, before running configure?
> See example below for erc32:
> $ mkdir erc32
> $ cd erc32
> $ $HOME/development/rtems/kernel/rtems/configure --prefix*=*$HOME
> /development/rtems/4.12
> \--target*=*sparc-rtems4.12 --enable-rtemsbsp*=*erc32 --enable-posix
> Regards, Alexey
> I have built it - I repeated the building process and programs were built.
> I think that something wrong
> was in my previous attempt, so the environment became dirty (as error
> meessage mentioned).
> Though, samples are built now, I have no output running them in
> arm-rtems4.12-gdb.
You built sparc/erc32 executables and tried to run them in an ARM gdb?!?!
Use sparc-rtems4.12-gdb
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20170315/8dfdfb47/attachment-0002.html>
