C++ iostream only working in Init, not in other RTEMS Tasks
Chris Coppens
Chris.Coppens at TopicProducts.com
Thu May 4 06:42:32 UTC 2017
Hello,
We are configuring maximum 64 file descriptors at the moment:
#define CONFIGURE_APPLICATION_EXTRA_DRIVERS DYPLO_DRIVER_TABLE_ENTRY
#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
#define CONFIGURE_MAXIMUM_DRIVERS 10
#define CONFIGURE_EXECUTIVE_RAM_SIZE (128*1024*1024)
#define CONFIGURE_STACK_SPACE_SIZE (10*1024*1024)
#define CONFIGURE_UNLIMITED_OBJECTS
#define CONFIGURE_INIT_TASK_STACK_SIZE (1024*1024)
#define CONFIGURE_INTERRUPT_STACK_SIZE (32*1024)
#define CONFIGURE_MINIMUM_TASK_STACK_SIZE (32*1024)
#define CONFIGURE_MAXIMUM_TASKS 3
#define CONFIGURE_MAXIMUM_SEMAPHORES 64
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
#define CONFIGURE_MICROSECONDS_PER_TICK 1000
#define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 64
#define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
#include <rtems/confdefs.h>
#define CONFIGURE_SHELL_COMMANDS_INIT
#define CONFIGURE_SHELL_COMMANDS_ALL
#include <rtems/shellconfig.h>
From: users [mailto:users-bounces at rtems.org] On Behalf Of Joel Sherrill
Sent: woensdag 3 mei 2017 22:42
To: Sebastian Huber
Cc: rtems-users at rtems.org
Subject: Re: C++ iostream only working in Init, not in other RTEMS Tasks
On Wed, May 3, 2017 at 12:46 AM, Sebastian Huber <sebastian.huber at embedded-brains.de<mailto:sebastian.huber at embedded-brains.de>> wrote:
On 03/05/17 07:15, Sebastian Huber wrote:
On 03/05/17 00:47, Chris Johns wrote:
On 2/5/17 6:03 pm, Sebastian Huber wrote:
On 02/05/17 09:35, Chris Coppens wrote:
Hello,
In our RTEMS application C++ iostream (e.g. "cout") is only working in
the “Init” function?
If I use “cout” in a RTEMS Task other than Init, no output is shown in
the console.
Any idea why this is happening?
The C++ library uses thread-local standard IO streams (Newlib feature)
for the global IO stream objects. I am not sure how to fix this
properly, but I guess a RTEMS-specific change in the libstdc++ would be
necessary.
Does a ticket exist for this? This should be fixed for 4.12.0 so please
set the milestone to 4.12.0 and blocker.
I don't know if a ticket exists. This issue exits in all RTEMS versions with C++ support. Since the initialization thread is restarted after the C++ global constructor calls this issue is more obvious now.
Before you make this a release blocker, then please find someone who can fix this.
Just for reference. The std::cout etc. is initialized here
https://gcc.gnu.org/viewcvs/gcc/trunk/libstdc%2B%2B-v3/src/c%2B%2B98/ios_init.cc?view=markup#l85
via a placement new. The "stdout" etc. is thread-local in Newlib. Using this for a global object like std::cout is quite broken.
Is there a test program to demonstrate that this is broken?
Since Cygwin also uses newlib, I have trouble believing this would
not also be broken there.
Going back to the original post. How many file descriptors are configured?
I am suspicious that the way C++ does it might require more file descriptors.
--joel
Phone : +49 89 189 47 41-16<tel:%2B49%2089%20189%2047%2041-16>
Fax : +49 89 189 47 41-09<tel:%2B49%2089%20189%2047%2041-09>
E-Mail : sebastian.huber at embedded-brains.de<mailto:sebastian.huber at embedded-brains.de>
Kind regards,
Chris Coppens
Software Designer
[cid:image140503.PNG at 2bf96124.46b8295e]
TOPIC Products
Materiaalweg 4
5681 RJ Best
T:
+31 (0) 499 33 69 69
Postbus 440
E:
5680 AK Best
W:
www.topicproducts.com<http://www.topicproducts.com>
The Netherlands
[cid:imagef17685.JPG at 0cd661b5.4692de6b] <https://www.facebook.com/TopicProducts> [cid:image142cc7.JPG at 4f054b35.4aa92564] <https://twitter.com/TopicProducts> [cid:image0b71b0.JPG at 780a0bf3.4a9dec55] <https://www.linkedin.com/company/topic-embedded-products>
Please consider the environment before printing this e-mail
users mailing list
users at rtems.org<mailto:users at rtems.org>
http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20170504/24eab703/attachment-0001.html>
Type: image/png
Desc: image140503.PNG
URL: <http://lists.rtems.org/pipermail/users/attachments/20170504/24eab703/attachment-0001.png>
Type: image/jpeg
Desc: imagef17685.JPG
URL: <http://lists.rtems.org/pipermail/users/attachments/20170504/24eab703/attachment-0003.jpe>
Type: image/jpeg
Desc: image142cc7.JPG
URL: <http://lists.rtems.org/pipermail/users/attachments/20170504/24eab703/attachment-0004.jpe>
Type: image/jpeg
Desc: image0b71b0.JPG
URL: <http://lists.rtems.org/pipermail/users/attachments/20170504/24eab703/attachment-0005.jpe>
