Rhealstone detailed benchmark
Mon May 29 07:05:11 UTC 2017
On 28/05/17 20:54, Russell Haley wrote:
> Is there any dtrace support in RTEMS (assuming that it's even a
> possibility)?
RTEMS has something similar with the trace linker:
https://devel.rtems.org/wiki/Developer/Tracing
I guess it would be possible to support DTrace via the libbsd since it
works in the FreeBSD kernel. There are some low-level issues, e.g. you
must be able to modify the code at run-time (difficult if you run from
read-only flash for example).
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
