Restarting an RTEMS app after a warm reset
Charles INGELS
charles.ingels at syderal.ch
Tue May 2 11:26:43 UTC 2017
Hi Sebastian,
thanks a lot for your answer. This confirms what I observed, and it
seems obvious that it cannot work without reloading the data at least.
Thanks !
Charles
Le 02.05.2017 à 11:25, Sebastian Huber a écrit :
> On 02/05/17 11:02, Charles INGELS wrote:
>> During the execution, I trigger a warm reset (without emptying the
>> SRAM content). The CPU then restarts executing the bootstrap which
>> will in turn directly try to execute the app in the same state in
>> which it was left before the warm reset. Since the SRAM has not been
>> reinitialized, the app is still there.
> This doesn't work, you have to restore at least the initial values of
> the global data (from PROM).
URL: <http://lists.rtems.org/pipermail/users/attachments/20170502/4e6ee620/attachment-0002.html>
