Has anyone tried to port Mono to RTEMS
Joel Sherrill
joel at rtems.org
Wed May 24 12:19:51 UTC 2017
On May 23, 2017 8:58 PM, "xuelin.tian at qkmtech.com" <xuelin.tian at qkmtech.com>
wrote:
Dear all,
Is that possible to port Mono to RTEMS? Has anyone tried this before?
As I notice that there is an open project in RTEMS projects.
Sometime ago, I was asked to provide an estimate for this. It had to be
between five and ten years ago because we were at the old office but after
we had done a few years of GSoC. I did enough work preparing the estimate
where I had the code building without too much effort. I saw the challenge
as getting the test suite running since you would have to create a test
harness and build/assembly helper that packaged the interpreted code with
the interpreter in order to run it. At that time, I envisioned having to
create a base image and a filesystem image per test.
Our POSIX was good enough then to avoid much trouble. It should only be
easier now since the POSIX support has improved.
There were a lot of Mono tests and I expected most to pass quickly. But
there was no way to know how many issues would be encountered and how many
root causes there would be. I expected to fix one or two things and then
run all the tests. That was where I expected time to be consumed.
FWIW I recall the GSoC date part because they thought we could magically
get students to do testing for free on a schedule. :)
I hope that helps. It is feasible but the key is testing.
--joel
Best wishes,
users mailing list
users at rtems.org
http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20170524/705266ba/attachment-0002.html>
