Has anyone tried to port Mono to RTEMS
xuelin.tian xuelin.tian at qkmtech.com
Wed May 24 16:52:19 UTC 2017
Hi Russell,
thank you for your reply. It helps a lot.
Could you share me the link or hub of this build system, that I can try to build Mono on my rtems based on ARM?
------------------ Original ------------------
Date:  Wed, May 24, 2017 11:46 PM
To:  "xuelin.tian"<xuelin.tian at qkmtech.com>; "users"<users at rtems.org>;
Subject:  Re: Has anyone tried to port Mono to RTEMS
        Sorry I should have also noted that mono and mono develop are well supported on FreeBSD 10.3+ on mono 4.2 and up. I think the latest is 4.6? Check freshports.org. Monodevelop works too iirc. TrueOS is a good way to get started.
Russ
        Sent from my BlackBerry 10 smartphone on the Virgin Mobile network.
Sent: Tuesday, May 23, 2017 6:58 PM
To: users at rtems.org
Subject: Has anyone tried to port Mono to RTEMS
Dear all,
Is that possible to port Mono to RTEMS? Has anyone tried this before?
As I notice that there is an open project in RTEMS projects.
 Best wishes,
URL: <http://lists.rtems.org/pipermail/users/attachments/20170525/f4ab1b9f/attachment-0002.html>
