Building rtems-4.9 using source builder failes
Joachim Rahn
Joachim.Rahn at helmholtz-berlin.de
Wed Nov 8 11:38:15 UTC 2017
Hello,
building rtems-4.9 using the source builder fails (I've attached the log for a powerpc build but even other builds
fail). Building rtems 4.10 and 4.11 works well.
I've got the Error.....
[...snip...]
Makefile:3698: recipe for target 'doc/gcc.info' failed
make[2]: *** [doc/gcc.info] Error 1
make[2]: *** Waiting for unfinished jobs....
../../gcc-4.3.2/gcc/doc/cppopts.texi:757: @itemx must follow @item
Makefile:3698: recipe for target 'doc/cpp.info' failed
make[2]: *** [doc/cpp.info] Error 1
/bin/bash ../../gcc-4.3.2/gcc/../move-if-change tmp-mlib.h multilib.h
echo timestamp > s-mlib
../../gcc-4.3.2/gcc/doc/sourcebuild.texi:579: warning: @itemx should not begin @table
../../gcc-4.3.2/gcc/doc/c-tree.texi:2328: @itemx must follow @item
../../gcc-4.3.2/gcc/doc/c-tree.texi:2334: @itemx must follow @item
../../gcc-4.3.2/gcc/doc/rtl.texi:3022: warning: @table has text but no @item
../../gcc-4.3.2/gcc/doc/c-tree.texi:10: warning: node next `Trees' in menu `RTL' and in sectioning `Tree SSA' differ
../../gcc-4.3.2/gcc/doc/c-tree.texi:663: warning: node next `Scopes' in menu `Functions' and in sectioning
`Declarations' differ
../../gcc-4.3.2/gcc/doc/c-tree.texi:885: warning: node next `Declarations' in menu `Attributes' and in sectioning
`Functions' differ
../../gcc-4.3.2/gcc/doc/c-tree.texi:885: warning: node prev `Declarations' in menu `Functions' and in sectioning
`Scopes' differ
../../gcc-4.3.2/gcc/doc/c-tree.texi:1250: warning: node next `Functions' in menu `Declarations' and in sectioning
`Attributes' differ
../../gcc-4.3.2/gcc/doc/c-tree.texi:1250: warning: node prev `Functions' in menu `Scopes' and in sectioning
../../gcc-4.3.2/gcc/doc/c-tree.texi:1853: warning: node prev `Attributes' in menu `Declarations' and in sectioning
`Functions' differ
../../gcc-4.3.2/gcc/doc/tree-ssa.texi:10: warning: node prev `Tree SSA' in menu `Control Flow' and in sectioning `Trees'
differ
../../gcc-4.3.2/gcc/doc/loop.texi:10: warning: node next `Loop Analysis and Representation' in menu `Machine Desc' and
in sectioning `RTL' differ
../../gcc-4.3.2/gcc/doc/rtl.texi:7: warning: node prev `RTL' in menu `Trees' and in sectioning `Loop Analysis and
Representation' differ
../../gcc-4.3.2/gcc/doc/cfg.texi:11: warning: node next `Control Flow' in menu `Tree SSA' and in sectioning `Machine
Desc' differ
../../gcc-4.3.2/gcc/doc/md.texi:7: warning: node prev `Machine Desc' in menu `Loop Analysis and Representation' and in
sectioning `Control Flow' differ
make[2]: *** [doc/gccint.info] Error 1
Makefile:3698: recipe for target 'doc/gccint.info' failed
make[2]: Leaving directory
'/opt/development/RTEMS/rtems-source-builder/rtems/build/powerpc-rtems4.9-gcc-4.3.2-newlib-1.16.0-x86_64-linux-gnu-1/build/gcc'
make[1]: *** [all-gcc] Error 2
Makefile:4761: recipe for target 'all-gcc' failed
make[1]: Leaving directory
'/opt/development/RTEMS/rtems-source-builder/rtems/build/powerpc-rtems4.9-gcc-4.3.2-newlib-1.16.0-x86_64-linux-gnu-1/build'
make: *** [all] Error 2
Makefile:704: recipe for target 'all' failed
shell cmd failed: /bin/sh -ex
/opt/development/RTEMS/rtems-source-builder/rtems/build/powerpc-rtems4.9-gcc-4.3.2-newlib-1.16.0-x86_64-linux-gnu-1/doit
error: building powerpc-rtems4.9-gcc-4.3.2-newlib-1.16.0-x86_64-linux-gnu-1
[...snip...]
Any advice is welcome...
Thanks and cheers, Joachim
________________________________
Helmholtz-Zentrum Berlin für Materialien und Energie GmbH
Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher Forschungszentren e.V.
Aufsichtsrat: Vorsitzender Dr. Karl Eugen Huthmacher, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Bernd Rech (kommissarisch), Thomas Frederking
Sitz Berlin, AG Charlottenburg, 89 HRB 5583
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
http://www.helmholtz-berlin.de
Type: application/zip
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20171108/e45274ee/attachment.zip>
