Building rtems-4.9 using source builder failes
Michael Davidsaver mdavidsaver at gmail.com
Wed Nov 8 19:06:48 UTC 2017
Hi Joachim,
A hack to skip info creation.
https://github.com/mdavidsaver/rsb/commit/f0bf5876ad96417db07a876845fbf833b10ced65
Michael
On 11/08/2017 05:38 AM, Joachim Rahn wrote:
> Hello,
> building rtems-4.9 using the source builder fails (I've attached the log for a powerpc build but even other builds
> fail). Building rtems 4.10 and 4.11 works well.
> I've got the Error.....
> [...snip...]
> Makefile:3698: recipe for target 'doc/gcc.info' failed
> make[2]: *** [doc/gcc.info] Error 1
> make[2]: *** Waiting for unfinished jobs....
> ../../gcc-4.3.2/gcc/doc/cppopts.texi:757: @itemx must follow @item
> Makefile:3698: recipe for target 'doc/cpp.info' failed
> make[2]: *** [doc/cpp.info] Error 1
> /bin/bash ../../gcc-4.3.2/gcc/../move-if-change tmp-mlib.h multilib.h
> echo timestamp > s-mlib
> ../../gcc-4.3.2/gcc/doc/sourcebuild.texi:579: warning: @itemx should not begin @table
> ../../gcc-4.3.2/gcc/doc/c-tree.texi:2328: @itemx must follow @item
> ../../gcc-4.3.2/gcc/doc/c-tree.texi:2334: @itemx must follow @item
> ../../gcc-4.3.2/gcc/doc/rtl.texi:3022: warning: @table has text but no @item
> ../../gcc-4.3.2/gcc/doc/c-tree.texi:10: warning: node next `Trees' in menu `RTL' and in sectioning `Tree SSA' differ
> ../../gcc-4.3.2/gcc/doc/c-tree.texi:663: warning: node next `Scopes' in menu `Functions' and in sectioning
> `Declarations' differ
> ../../gcc-4.3.2/gcc/doc/c-tree.texi:885: warning: node next `Declarations' in menu `Attributes' and in sectioning
> `Functions' differ
> ../../gcc-4.3.2/gcc/doc/c-tree.texi:885: warning: node prev `Declarations' in menu `Functions' and in sectioning
> `Scopes' differ
> ../../gcc-4.3.2/gcc/doc/c-tree.texi:1250: warning: node next `Functions' in menu `Declarations' and in sectioning
> `Attributes' differ
> ../../gcc-4.3.2/gcc/doc/c-tree.texi:1250: warning: node prev `Functions' in menu `Scopes' and in sectioning
> ../../gcc-4.3.2/gcc/doc/c-tree.texi:1853: warning: node prev `Attributes' in menu `Declarations' and in sectioning
> `Functions' differ
> ../../gcc-4.3.2/gcc/doc/tree-ssa.texi:10: warning: node prev `Tree SSA' in menu `Control Flow' and in sectioning `Trees'
> differ
> ../../gcc-4.3.2/gcc/doc/loop.texi:10: warning: node next `Loop Analysis and Representation' in menu `Machine Desc' and
> in sectioning `RTL' differ
> ../../gcc-4.3.2/gcc/doc/rtl.texi:7: warning: node prev `RTL' in menu `Trees' and in sectioning `Loop Analysis and
> Representation' differ
> ../../gcc-4.3.2/gcc/doc/cfg.texi:11: warning: node next `Control Flow' in menu `Tree SSA' and in sectioning `Machine
> Desc' differ
> ../../gcc-4.3.2/gcc/doc/md.texi:7: warning: node prev `Machine Desc' in menu `Loop Analysis and Representation' and in
> sectioning `Control Flow' differ
> make[2]: *** [doc/gccint.info] Error 1
> Makefile:3698: recipe for target 'doc/gccint.info' failed
> make[2]: Leaving directory
> '/opt/development/RTEMS/rtems-source-builder/rtems/build/powerpc-rtems4.9-gcc-4.3.2-newlib-1.16.0-x86_64-linux-gnu-1/build/gcc'
> make[1]: *** [all-gcc] Error 2
> Makefile:4761: recipe for target 'all-gcc' failed
> make[1]: Leaving directory
> '/opt/development/RTEMS/rtems-source-builder/rtems/build/powerpc-rtems4.9-gcc-4.3.2-newlib-1.16.0-x86_64-linux-gnu-1/build'
> make: *** [all] Error 2
> Makefile:704: recipe for target 'all' failed
> shell cmd failed: /bin/sh -ex
> /opt/development/RTEMS/rtems-source-builder/rtems/build/powerpc-rtems4.9-gcc-4.3.2-newlib-1.16.0-x86_64-linux-gnu-1/doit
> error: building powerpc-rtems4.9-gcc-4.3.2-newlib-1.16.0-x86_64-linux-gnu-1
> [...snip...]
> Any advice is welcome...
> Thanks and cheers, Joachim
> ________________________________
> Helmholtz-Zentrum Berlin für Materialien und Energie GmbH
> Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher Forschungszentren e.V.
> Aufsichtsrat: Vorsitzender Dr. Karl Eugen Huthmacher, stv. Vorsitzende Dr. Jutta Koch-Unterseher
> Geschäftsführung: Prof. Dr. Bernd Rech (kommissarisch), Thomas Frederking
> Sitz Berlin, AG Charlottenburg, 89 HRB 5583
> Postadresse:
> Hahn-Meitner-Platz 1
> D-14109 Berlin
> http://www.helmholtz-berlin.de
> users mailing list
> users at rtems.org
