Building rtems-4.9 using source builder failes
Joachim Rahn Joachim.Rahn at helmholtz-berlin.de
Fri Nov 10 06:59:16 UTC 2017
Hi Michael,
thanks, hack works for me....
Cheers, Joachim
On 08.11.2017 20:06, Michael Davidsaver wrote:
> Hi Joachim,
> A hack to skip info creation.
> https://github.com/mdavidsaver/rsb/commit/f0bf5876ad96417db07a876845fbf833b10ced65
> Michael
> On 11/08/2017 05:38 AM, Joachim Rahn wrote:
>> Hello,
>> building rtems-4.9 using the source builder fails (I've attached the log for a powerpc build but even other builds
>> fail). Building rtems 4.10 and 4.11 works well.
>> I've got the Error.....
>> [...snip...]
>> Makefile:3698: recipe for target 'doc/gcc.info' failed
>> make[2]: *** [doc/gcc.info] Error 1
>> make[2]: *** Waiting for unfinished jobs....
>> ../../gcc-4.3.2/gcc/doc/cppopts.texi:757: @itemx must follow @item
>> Makefile:3698: recipe for target 'doc/cpp.info' failed
>> make[2]: *** [doc/cpp.info] Error 1
>> /bin/bash ../../gcc-4.3.2/gcc/../move-if-change tmp-mlib.h multilib.h
>> echo timestamp > s-mlib
>> ../../gcc-4.3.2/gcc/doc/sourcebuild.texi:579: warning: @itemx should not begin @table
>> ../../gcc-4.3.2/gcc/doc/c-tree.texi:2328: @itemx must follow @item
>> ../../gcc-4.3.2/gcc/doc/c-tree.texi:2334: @itemx must follow @item
>> ../../gcc-4.3.2/gcc/doc/rtl.texi:3022: warning: @table has text but no @item
>> ../../gcc-4.3.2/gcc/doc/c-tree.texi:10: warning: node next `Trees' in menu `RTL' and in sectioning `Tree SSA' differ
>> ../../gcc-4.3.2/gcc/doc/c-tree.texi:663: warning: node next `Scopes' in menu `Functions' and in sectioning
>> `Declarations' differ
>> ../../gcc-4.3.2/gcc/doc/c-tree.texi:885: warning: node next `Declarations' in menu `Attributes' and in sectioning
>> `Functions' differ
>> ../../gcc-4.3.2/gcc/doc/c-tree.texi:885: warning: node prev `Declarations' in menu `Functions' and in sectioning
>> `Scopes' differ
>> ../../gcc-4.3.2/gcc/doc/c-tree.texi:1250: warning: node next `Functions' in menu `Declarations' and in sectioning
>> `Attributes' differ
>> ../../gcc-4.3.2/gcc/doc/c-tree.texi:1250: warning: node prev `Functions' in menu `Scopes' and in sectioning
>> ../../gcc-4.3.2/gcc/doc/c-tree.texi:1853: warning: node prev `Attributes' in menu `Declarations' and in sectioning
>> `Functions' differ
>> ../../gcc-4.3.2/gcc/doc/tree-ssa.texi:10: warning: node prev `Tree SSA' in menu `Control Flow' and in sectioning `Trees'
>> differ
>> ../../gcc-4.3.2/gcc/doc/loop.texi:10: warning: node next `Loop Analysis and Representation' in menu `Machine Desc' and
>> in sectioning `RTL' differ
>> ../../gcc-4.3.2/gcc/doc/rtl.texi:7: warning: node prev `RTL' in menu `Trees' and in sectioning `Loop Analysis and
>> Representation' differ
>> ../../gcc-4.3.2/gcc/doc/cfg.texi:11: warning: node next `Control Flow' in menu `Tree SSA' and in sectioning `Machine
>> Desc' differ
>> ../../gcc-4.3.2/gcc/doc/md.texi:7: warning: node prev `Machine Desc' in menu `Loop Analysis and Representation' and in
>> sectioning `Control Flow' differ
>> make[2]: *** [doc/gccint.info] Error 1
>> Makefile:3698: recipe for target 'doc/gccint.info' failed
>> make[2]: Leaving directory
>> '/opt/development/RTEMS/rtems-source-builder/rtems/build/powerpc-rtems4.9-gcc-4.3.2-newlib-1.16.0-x86_64-linux-gnu-1/build/gcc'
>> make[1]: *** [all-gcc] Error 2
>> Makefile:4761: recipe for target 'all-gcc' failed
>> make[1]: Leaving directory
>> '/opt/development/RTEMS/rtems-source-builder/rtems/build/powerpc-rtems4.9-gcc-4.3.2-newlib-1.16.0-x86_64-linux-gnu-1/build'
>> make: *** [all] Error 2
>> Makefile:704: recipe for target 'all' failed
>> shell cmd failed: /bin/sh -ex
>> /opt/development/RTEMS/rtems-source-builder/rtems/build/powerpc-rtems4.9-gcc-4.3.2-newlib-1.16.0-x86_64-linux-gnu-1/doit
>> error: building powerpc-rtems4.9-gcc-4.3.2-newlib-1.16.0-x86_64-linux-gnu-1
>> [...snip...]
>> Any advice is welcome...
>> Thanks and cheers, Joachim
>> ________________________________
>> Helmholtz-Zentrum Berlin für Materialien und Energie GmbH
>> Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher Forschungszentren e.V.
>> Aufsichtsrat: Vorsitzender Dr. Karl Eugen Huthmacher, stv. Vorsitzende Dr. Jutta Koch-Unterseher
>> Geschäftsführung: Prof. Dr. Bernd Rech (kommissarisch), Thomas Frederking
>> Sitz Berlin, AG Charlottenburg, 89 HRB 5583
>> Postadresse:
>> Hahn-Meitner-Platz 1
>> D-14109 Berlin
>> http://www.helmholtz-berlin.de
>> users mailing list
>> users at rtems.org
Postadresse:
D-14109 Berlin
