Building RSB (RTEMS Source Builder) on Windows 10
Wed Nov 15 05:36:54 UTC 2017
On 15/11/2017 07:44, Jacob Saina wrote:
>     >> 2) I've noticed that the "rsb-report-arm-rtems4.11-kernel...." file (attached)
>     >> says "RSB: not a valid repo." What does this mean?
>     > I suggest you try a build with `--without-rtems` on the command line. ...
>     I've kicked off a build --without-rtems. But is this related to the "RSB:
>     not a valid repo" message?
> I'm home sick
I hope you are recovering.
> so I can't attach logs, but I've been informed that the
> --without-rtems build has failed after 45 minutes:
> error: building arg4n2xwml
Thanks. I will try and start a build before I leave tonight.
