Stack_check_Dump_threads_usage printing out the wrong values
groups at chichak.ca groups at chichak.ca
Fri Nov 17 04:27:26 UTC 2017
I fear blowing up builds all over the world, but I’ll give it a try.
A
> On 2017-November-16, at 21:21, Chris Johns <chrisj at rtems.org> wrote:
> On 17/11/2017 15:05, groups at chichak.ca wrote:
>> (I don’t know how to proceed with getting this reported/fixed.)
> Please head to the wiki (https://devel.rtems.org/) and select the link in the
> "Reporting a bug" column of the Releases Table for the release you are reporting
> the bug against. You will need an account.
> - Clone the git repo and select the branch.
> - Make the change and test.
> - Commit the change with a summary as the first line and then if
>  you need more detail add a body. End the commit message with
>  "Close #12345." with the ticket number.
>    eg git commit
>     libmisc: Fix formatting in Stack_check_Dump_threads_usage
>     Close #12345.
> - Enter 'git format-patch -1'
> - Attach the patch to the ticket.
> Please ask if you are not sure or something does not work.
> Thanks
> Chris
