An issue with ARM interrupts revisits.
Mr. Andrei Chichak groups at chichak.ca
Thu Nov 23 17:25:18 UTC 2017
One question though, where can I tap into the OS to figure out what priorities my ISRs are actually using?
If there is something odd with the encoding that ST uses for priorities, I could actually be fighting an issue with CubeMX for F7 that is causing my ISRs to be interpreted as NMIs again.
A
> On 2017-November-23, at 12:28 AM, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
> On 22/11/17 07:33, Sebastian Huber wrote:
>> I have absolutely no idea how you can end up in _ARMV7M_Thread_dispatch() with an unexpected interrupt level.
> I think if you call an operating system service which leads to a thread dispatch in a NMI handler, then you could end up with this situation. You can test this with the following patch and run the spintrcritical10 test program.
> diff --git a/c/src/lib/libbsp/arm/shared/armv7m/clock/armv7m-clock-config.c b/c/src/lib/libbsp/arm/shared/armv7m/clock/armv7m-clock-config.c
> index 1c17a92cb5..f0ebe1506f 100644
> --- a/c/src/lib/libbsp/arm/shared/armv7m/clock/armv7m-clock-config.c
> +++ b/c/src/lib/libbsp/arm/shared/armv7m/clock/armv7m-clock-config.c
> @@ -104,7 +104,7 @@ static void _ARMV7M_Systick_handler_install(void)
>  _ARMV7M_Set_exception_priority_and_handler(
>    ARMV7M_VECTOR_SYSTICK,
> -    BSP_ARMV7M_SYSTICK_PRIORITY,
> +    1,
