An issue with ARM interrupts revisits.
Fri Nov 24 08:00:10 UTC 2017
On 23/11/17 18:25, Mr. Andrei Chichak wrote:
> One question though, where can I tap into the OS to figure out what priorities my ISRs are actually using?
> If there is something odd with the encoding that ST uses for priorities, I could actually be fighting an issue with CubeMX for F7 that is causing my ISRs to be interpreted as NMIs again.
You can use _ARMV7M_Get_exception_priority() to get the exception
priority. Vector is from 0 to ARMV7M_VECTOR_IRQ(NVIC max IRQ number).
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
