RTEMS FPGA memory access failed
jameszxj jameszxj at gmail.com
Tue Nov 21 08:42:53 UTC 2017
Check your MMU config, uboot do not init MMU,so you can access all address.
------------------ Original ------------------
Date:  Tue, Nov 21, 2017 03:23 AM
To:  "users at rtems.org"<users at rtems.org>;
Subject:  RTEMS FPGA memory access failed
Hi,
I have a DE0 Nano SoC (Cyclone V) board that runs rtems 4.11. When RTEMS
accesses the FPGA memory space (0xc0000000 - 0xfbffffff) via the
HPS2FPGA AXI Bridge by using command - mdump, the system got reset and
failed. The FPGA  is programmed and the HPS2FPGA AXI Bridge is working.
The U-boot can access the FPGA memory address starting 0xc00000000. Does
anyone knows why rtems can't access the FPGA? and how to solve it.
Thanks
Jay
users mailing list
users at rtems.org
http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20171121/d5738d5e/attachment-0002.html>
